Author Topic: Brake Piston Stuck  (Read 9372 times)
Offline Dave1234
Brake Piston Stuck
« on: September 17, 2016, 01:42:23 PM »
Hi all, still trying to sort out thr front brake on my 550K3, the wheel caliper piston is stuck all the way in, how do I get it out? I think it is partially seized. Also the front disc plate was rubbing on the fork bottom, I slacken the front wheel clamps and tap the spindle slighty which released it but how much tolerance should you have between the disc plate and fork bottom leg?
Offline Dave1234
Re: Brake Piston Stuck
« Reply #1 on: September 17, 2016, 02:19:40 PM »
Or what other models caliper fit the 550K3?
Offline Chris400F
« Reply #2 on: September 17, 2016, 02:52:44 PM »
« Reply #3 on: September 17, 2016, 03:06:54 PM »
If you don't fancy doing it yourself you can post it to me and I will strip it and quote for parts
Offline Dave1234
« Reply #4 on: September 17, 2016, 03:37:56 PM »
« Reply #5 on: September 17, 2016, 04:49:53 PM »
They are all a different thread but will screw in about 1 1/2 turns and will work
Offline Dave1234
« Reply #6 on: September 19, 2016, 09:21:07 AM »
See page 8 of this thread.
http://www.sohc.co.uk/index.php/topic,10585.msg78485.html#msg78485
Thanks Chris, the grease gun trick worked a treat, you learn something new everyday.  ;D ;D ;D
Offline Dave1234
« Reply #7 on: September 21, 2016, 06:19:38 PM »
Anyone got any ideas on the disc plate and lower fork outer clearance?
« Reply #8 on: September 22, 2016, 06:25:56 AM »
Only reasons for disc rubbing are incorrect assembly or shot wheel bearings
Offline Rob.b (Rob Birkett - RIP)
« Reply #9 on: September 22, 2016, 09:04:30 AM »
hi,
For correct parts and assembly use this link:
http://www.cmsnl.com/honda-cb550k3-four-england_model14671/partslist/F09.html#results
The clearance between disc outer face and fork leg inner should be about 5mm. I couldn't measure mine accurately and its on a CB500K but I'm pretty sure its the same as the parts are mostly interchangeable.
Good  luck with it
Rob
Offline matthewmosse
« Reply #10 on: September 22, 2016, 12:07:05 PM »
That detail has been bugging me, I think Brian is right, in the normal course of things the front wheel will only sit in its proper place, so if its able to move then either a part is in wrong way around or a wrong part is fitted, or you have very knackered wheel bearings indeed. I would suspect wrong bits or a spacer fitted backwards, or the wheel nut wrongly fitted.
Offline paulbaker1954
« Reply #11 on: September 23, 2016, 11:44:52 PM »
I Agee with Ken I had exactly the same problem when I had new tyre fitted and just took the wheels in . The fitter reassembled the spindle wrongly. Had me scratching my head for ages.
2016 Yamaha MT09 Tracer
1971 Honda CB500 Four K0
Offline Dave1234
« Reply #12 on: September 25, 2016, 10:18:22 AM »
I think your right about the spindle being fitted the wrong way round. I have just visited David Silver's museum in Leiston, Suffolk and looked at his CB550 and noticed it was the other way round. I bought the bike earlier this year and have realised quite a few things butchered on the bike. Cheers for all the help.
By the way David has got a nice lot of bikes up there in the museum, even one that used to sit in my garage until a Top Gear presenter bought it then sold it to David. Lol
« Reply #13 on: September 25, 2016, 06:03:23 PM »
It wasn't the CB250K0 was it?
Offline Dave1234
« Reply #14 on: September 25, 2016, 06:49:22 PM »
No Ash, have another go. Lol
