Author Topic: pd46a carburetor help  (Read 4969 times)
Offline davidrsmith
« on: September 20, 2016, 09:24:01 PM »
Hi
Thanks to those people who replied to my previous post about stuck throttle slides.
I have now got them freed and cleaned, and I am now rebuilding the carbs but I have a small problem, on two of the carbs the pilot jet plain washer and rubber seal are stuck in their housing, how can I get them out, and does anyone know where I can get a couple of new washers?
Dave
Offline Lynx
Re: pd46a carburetor help
« Reply #1 on: September 28, 2016, 10:21:38 PM »
Hi Dave,
I think this is what you want
http://www.cmsnl.com/honda-cb550k3-four-england_model14671/screw-set_16016393004/#.V-w0AYgrLGg
You can usually get them out with a pin. Maybe soak them in PlusGas first.
Yamaha RD500LC
Triumph Speed Triple RS.
Previous bikes include
CB350K3 x2
CB250G5
CX500C
VF500F2
VF1000FE
Offline Seabeowner
« Reply #2 on: September 30, 2016, 09:30:05 AM »
Just did this yesterday. Spray of carb cleaner, then a short length of thin wire (fuse or a piece from a multistrand) with a hook bent at the end and they come out easy.
Rebuilt carbs after cleaning all day with a load of new parts. Checked float heights etc. Bike is a pig. Dead or 5000rpm. I hate pd carbs.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
Offline Lynx
« Reply #3 on: September 30, 2016, 09:49:57 AM »
Have you used compressed air on them? I managed to blow out a small brass blanking ball once without realising. I had the carbs off 3 times before I found the problem.
Sent from my HTC Desire 530 using Tapatalk
Yamaha RD500LC
CB350K3 x2
CB250G5
CX500C
VF500F2
VF1000FE
Offline Seabeowner
« Reply #4 on: October 01, 2016, 11:21:13 AM »
Didn't use compressed air. Just a spray can of carb cleaner. But didn't remove the slow jet which is next to the main jet. This appears to be just pushed in with interference fit and didn't want to mash it. Anybody remove them?
Will take apart and remove everything and soak the bodies. Will look up best soaking solutions: there have been plenty on here in the past.
Offline Lynx
« Reply #5 on: October 01, 2016, 11:24:21 AM »
They'll be held in with an o ring.
Yamaha RD500LC
CB350K3 x2
CB250G5
CX500C
VF500F2
VF1000FE
Offline Seabeowner
« Reply #6 on: October 01, 2016, 12:38:45 PM »
It's a common topic on the US site as a lot more sold over there. Just a push fit. (how much £ to save one tapped hole and threaded jet?) If you're brave: pliers and give it a tug and a turn and they are out....or not....
« Reply #7 on: October 01, 2016, 02:29:29 PM »
Never had a problem getting them out with vice grips twist and turn pluss always blocked, Sirius in Canada sell replacements
Offline Lynx
« Reply #8 on: October 01, 2016, 02:35:13 PM »
Strange design 🤔
Yamaha RD500LC
CB350K3 x2
CB250G5
CX500C
VF500F2
VF1000FE
Offline matthewmosse
« Reply #9 on: October 02, 2016, 09:01:20 AM »
The other day I tried cellulose thinners dumped right into the tank, then running the engine on the thinners for a engine that was proving troublesome thanks to stale fuel residue constantly re blocking the jets, seems to have worked so far, another handy hint I got off another forum was that gas welders nozle reamers work a treat to clean out blocked jets, especially in conjunction with a bit of thinners to soften the stale fuel varnish. Just be carefull to use an appropriately sized reamer to avoid enlarging the drillings - start small. The website I got that off stated a specific size for cirtain engines but was directed at Kohler engines so us sohc honda owners have to figure out for ourselfs which reamer to use.
