Author Topic: CB750 Gasket sets - any recommendations  (Read 7839 times)
Offline Zunspec
« on: October 13, 2016, 02:09:10 PM »
Hello,
I intend to lift the head on my 750F1 engine to re-lap the valves to address a small issue with low compression readings.  Is there a favoured brand (apart from Honda OE) for a top end gasket kit.  I do not have adequate knowledge to order all the gaskets, O-rings etc. individually.
Cheers  Geoff
Re: CB750 Gasket sets - any recommendations
« Reply #1 on: October 14, 2016, 10:38:07 AM »
I've recently bought an Athena set, after reading good reviews, and while I'm not in a position to use it yet, it seems good quality, and includes stuff like the rubber seals that go in the cylinder head, and a load of O rings. I guess only when I can build the motor I'll find what's missing.
Ash says that the NP sets are very good, but the only CB750 set I could find turned out to be incomplete, as the 'borrowers' had been at in while it was in stock.
The ebay listing I bought from shows what you are going to get, unlike most ads that show a set in its packaging.
http://www.ebay.co.uk/itm/For-Honda-CB-750-K-Four-1972-1975-Athena-Complete-Gasket-Kit/302093894735
Offline Zunspec
« Reply #2 on: October 14, 2016, 10:47:10 AM »
Thanks MrDavo,
That looks a pretty comprehensive set.
Cheers  Geoff
« Reply #3 on: October 14, 2016, 02:53:45 PM »
Dont be tempted by the price of the Cruzinimage set. Last one I had for the 750 was rubbish.
Offline Zunspec
« Reply #4 on: October 14, 2016, 04:31:15 PM »
Hello Roy,
The CruzinImage products do seem to be bit hit-or-miss.  Some of their kit is good, others.....questionable.  I like the offering from Cycle-X but their shipping is more than the price of the gasket kit.  I'm not in a rush, the top end re-fresh will be a winter project.
« Reply #5 on: October 14, 2016, 05:45:11 PM »
Your right about Cruzinimage being hit and miss. I should have said the kit I had off them for the CB350F was very good. Just the 750 kit that was rubbish, and others have said the same.
« Reply #6 on: October 16, 2016, 08:45:17 AM »
I always use original head gasket and Vesrah for the rest. Though Vesrah do not include the pucks anymore on the 750K's anymore.
Offline Zunspec
« Reply #7 on: October 16, 2016, 11:46:26 AM »
Thanks Trigger,
During my searches on the subject several times I have seen the "use genuine Honda headgaskets", I'll do the same. Although I can remove the top end whilst the engine is still in the frame on the Seeley so not so much work compared to having to remove the engine to replace a head gasket.
I'm still trying to work out what function these "pucks" perform but obviously they are needed.
Cheers  Geoff
« Reply #8 on: October 16, 2016, 04:56:40 PM »
They seal up the holes you need to get a socket in to torque the head
Offline Zunspec
« Reply #9 on: October 17, 2016, 12:29:49 AM »
Thanks Bryan, More knowledge gained.
« Last Edit: October 18, 2016, 12:38:10 PM by Zunspec »
« Reply #10 on: November 05, 2016, 10:17:27 AM »
Interesting discussion from the 750 Sandcastonly site. Personally I am just going to use the NP one I have with the extra 'O' rings detailed in the Service Bulletin. The NP gasket set BTW is the only one I have found with the rubbers for inbetween the cylinder fins included in the gasket set (not sure on Honda one ...so long since I have seen one). The pucks are used to seal the holes that give access to the recessed  head nuts.
Don R
Head gasket Q?
« on: November 02, 2016, 01:01:30 PM »
Reply with quoteQuote
 Is there a source for proper head gaskets for an early head? If I were to contact cometic about making some I'd assume I need the thickness and composition information. Not having one for comparison I wonder how close the rest of the gasket is besides the center bolt?
kp
Administrator
Hero Member
View Profile  Email  Personal Message (Offline)
Re: head gasket Q?
« Reply #1 on: November 02, 2016, 03:19:19 PM »
Other than the extra hole at the front the other bolt holes are smaller in diameter. The newer gaskets also have a sticky area between cylinders 2 and 3 to help with sealing which was a good feature.The early production gaskets didn't have this. I'm sure you would get a lot of interest if these were remanufactured
Report to moderator     Logged
Yabba Dabba  KP
Steve Swan
Administrator
Hero Member
Re: head gasket Q?
« Reply #2 on: November 03, 2016, 10:21:16 PM »
the sticky head gaskets make head removal a horror.  the issue of preventing oil leaks is as much in the thickness of the head gasket
 as it is in the thickness of the O-rings fitted.  I've started using Vesrah head gaskets and a slightly thicker O-ring and had no oil leaks running the engine on the test stand and during operation in the frame.  i don't have the thicker O-ring measurements as i write this, I  do have the measurements at my shop.
Steve Swan
« Last Edit: November 05, 2016, 10:28:07 AM by AshimotoK0 »
Offline Phil Ward (RIP)
« Reply #11 on: November 12, 2016, 10:51:39 AM »
Ash
Do you have the size of the extra thickness o rings that is referred to in the quoted post above. I remember fitting them to my last rebuild but didn't keep the info - It will same me trawling .net again if you have the size
« Reply #12 on: November 13, 2016, 09:17:31 AM »
From memory it was something like 15 mm i.d. x 1.5 dia. in Viton   but that's purely from memory of a very old email sent to me. I have emailed the restorer who originally gave me the info and I will get back to you Phil
« Reply #13 on: November 13, 2016, 09:26:52 AM »
It will all depend on the thickness of the gasket, the ID of the stud hole in the gasket and what 750 engine it is for ;)
« Reply #14 on: November 13, 2016, 10:02:28 PM »
My 'recent topics' screen has disappeared! Is it just my PC or is it the same for everyone?
