Author Topic: Make your own clutch pushrod? (CB500)  (Read 8447 times)
Online SteveD CB500K0
« on: February 06, 2017, 09:12:36 AM »
Here's something from way back (and a long way away)
Has anyone here done this or have DS started making their own / found a secret stash ?
http://forums.sohc4.net/index.php/topic,84249.msg949313.html
Offline flatfour
Re: Make your own clutch pushrod? (CB500)
« Reply #1 on: February 06, 2017, 09:26:26 AM »
After looking for one of these for many years (mine was broken when I bought the bike in 2004 and an engineer friend made a replacement, however it was never quite hard enough and needed regular adjustment) I was lucky enough to be able to buy a couple from Trigger on this site.
I've used one, but if you need it and he can't supply, you are welcome to my spare for the same price that I bought it for.
The clutch (with the new pushrod fitted) is the best that it's ever been!
« Reply #2 on: February 06, 2017, 10:08:52 AM »
The measurements on the USA site in 2011 are wrong, a 9.5mm rod doesn't fit in to a 8mm hole ;)
« Reply #3 on: February 06, 2017, 10:31:18 AM »
I use one of Triggers excellent steel
pushrods.well worth the money. Fits perfectly. It would take hours to make.not worth struggling unless you have a lathe and lots of time.
Offline MCTID
« Reply #4 on: February 06, 2017, 10:17:16 PM »
It's a 'long time ago' but in my Apprentice Engineer days in the 60's/ 70's I recall making various bit and bobs out of Silver Steel (easily available from Engineering Suppliers) which were easy to heat treat and (dependant upon the heat treatment) were quite hard and durable.
Worth a try......and if somebody gets it right there may be a bit of business to be had with Forum Members.
« Reply #5 on: February 06, 2017, 10:35:28 PM »
Keep up Alan  ;D ;D ;D Trigger has been making these from silver steel and selling them to forum members for yonks  ::) ::)
Offline MCTID
« Reply #6 on: February 06, 2017, 10:41:41 PM »
Cheers Julie.........your 'Bedside Manner' isn't the best is it ? .....nobody mentioned Silver Steel in the thread hence my two pennyworth.
I'll now keep my gob shut until 2020.....and sit in a darkened cubby hole under the stairs.
LOL.
Offline petermigreen
« Reply #7 on: March 24, 2017, 06:52:21 PM »
Has Trigger got any left? How much are they please?
Peter.
« Last Edit: March 24, 2017, 07:02:14 PM by petermigreen »
Offline Green1
« Reply #8 on: March 24, 2017, 07:31:29 PM »
Trigs been strangely quiet today I recon Julies whopped him one  ;D ;D
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Triumph tiger 800
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
« Reply #9 on: March 24, 2017, 07:45:48 PM »
LOL
« Reply #10 on: March 24, 2017, 08:03:29 PM »
Peter.
I am out of stock at the moment and don't have the time to make any at the moment. If you PM flatfour, he may still have one.
« Reply #11 on: March 24, 2017, 09:07:08 PM »
Okay, no problem thanks for your response. I know an engineer who's tooled up to tackle the job.
Mine's broke  :(
« Reply #12 on: March 24, 2017, 09:28:27 PM »
Mine's broke  :(
(Attachment Link)
 a very common issue
« Reply #13 on: March 25, 2017, 06:10:59 PM »
usually caused by a loose chain!
« Reply #14 on: March 25, 2017, 06:30:06 PM »
That makes sense then because whoever ran my bike last left the chain so loose you could almost lift it off the front sprocket without slackening off the rear wheel!
I've sourced some Stainless 8mm diameter rod and am going to make a few up.
Thanks for your replies.
Peter.
