Author Topic: Removing head with engine in.  (Read 7814 times)
Offline onethumb
« on: February 18, 2017, 02:03:12 PM »
So just noticed that number one cylinder is blowing air back through the carb. I've slackened of the tappets and although not as bad it's still there. Bad times.
I don't want to take the engine out so what are the thoughts of people on here about doing it with the engine in place.
Is it possible that the seats are original from the days of leaded?
Please help I'm a bit down after how close I was to finishing.
Thanks. Steve.
Offline MarkCR750
Re: Removing head with engine in.
« Reply #1 on: February 18, 2017, 02:20:56 PM »
Sorry Steve it's just not possible, be sure you have got a problem with the valves though, do a compression check.
Triumph Scrambler 1200X
CCM 604 dual sport
1977 K7 CR750
Ducati 900SS
James Captain 197 x2
Norman Nippy 50cc
Sir J.Stewart.
Offline onethumb
« Reply #2 on: February 18, 2017, 02:29:00 PM »
Thanks mark. Is that not possible about the seats or removing the head with the engine in?
Offline hondarc166
« Reply #3 on: February 18, 2017, 02:55:25 PM »
i think it's removing the head
Offline onethumb
« Reply #4 on: February 18, 2017, 02:56:51 PM »
That's not god news.
« Reply #5 on: February 18, 2017, 03:07:58 PM »
Sorry head won't come off unless you remove the engine or cut the frame tubes and weld in a removable section.
Sent from my Nexus 6 using Tapatalk
« Reply #6 on: February 18, 2017, 03:39:31 PM »
Valve seats are fine for unleaded, what engine is it as the F2 wears out valve guides
Offline onethumb
« Reply #7 on: February 18, 2017, 04:35:29 PM »
Hi Bryan. It's the 1978 f2. Doh. Any recommendations for getting new ones pressed in, and do I now do all of them?
« Reply #8 on: February 18, 2017, 06:42:18 PM »
You will need to remove and totally strip the head and check for wear between valve stems and guides, if new are required (exhaust wear more than inlet) you need to find a motorcycle competent machinist as the guides need reaming to size after fitting and the valve seats will need re-cutting. I believe there is an American firm that does replacement parts but be prepared to sit down before getting prices, I would expect just the work to be over £100 and parts £200+ not including gaskets
http://www.dynoman.net/engine/valves/index.html#F2 Valves and guides $250 ish plus shipping
« Last Edit: February 18, 2017, 06:47:47 PM by Bryanj »
« Reply #9 on: February 18, 2017, 07:07:01 PM »
Valve seats re- ground Bryan  ;) Old Honda seats do not like to be cut  ;D
« Reply #10 on: February 18, 2017, 07:09:43 PM »
Would that be because you now have a valve seat grinder Trig?
« Reply #11 on: February 18, 2017, 07:11:09 PM »
Yes I have a Honda one  ;) >>> http://www.sohc.co.uk/index.php/topic,11733.0.html
Offline onethumb
« Reply #12 on: February 18, 2017, 07:32:36 PM »
Trig, pm sent.
« Reply #13 on: February 19, 2017, 01:16:50 AM »
You are quite right but most people associate "ground" with a stick and paste not what we understand mate
« Reply #14 on: February 19, 2017, 06:30:53 AM »
Lap  ;D
