CB750
CB750 Carb body - desparately seeking
Topic: CB750 Carb body - desparately seeking (Read 4927 times)
Phil Ward (RIP)
March 07, 2017, 07:04:10 PM »
Now that I have stripped the set of carbs I bought last year for the CR750 project, I've discovered that no 4 carb is damaged (looks like they have been dropped) - the float bowl joint lip - on the main body is chipped. The mouth of the airfilter opening is also bashed. Before I go and buy a set of carbs just to use one carb body, has anybody got a spare they can sell me? Its just the body I need,
Trigger
Engines built on reputation, not advertising.
Re: CB750 Carb body - desparately seeking
March 07, 2017, 07:16:34 PM »
show a pic of the damage, lip is not a problem
Phil Ward (RIP)
March 07, 2017, 07:31:46 PM »
I know it would seal on the rubber seal (lip is to locate seal) - but the lip is visible on and as the rest of the carbs will be visibly like new (all re-plated/polished), just wanted to replace while they are in a milion bits - just wanted it 100% Graham
MeilakJ
SOHC Member
Life is what you make it!!
March 07, 2017, 07:34:49 PM »
Maybe this can help
http://forums.sohc4.net/index.php/topic,163931.0.html
John
Phil Ward (RIP)
March 07, 2017, 07:47:17 PM »
Cheers John - will see if anybody from UK can help to avoid postage costs from the States - if not its an option
RGP750
"always look on the bright side of life"
March 07, 2017, 07:59:34 PM »
This any good Phil?
Rich
1973 CB175
1972 CB175
1959 BSA Super rocket
1927 960cc Matchless 'v' twin
1969 750 K0
Phil Ward (RIP)
March 07, 2017, 10:20:15 PM »
I think that is No 3 carb Rich - its No 4 I'm after (air screw on right and fuel feed/brass male pipe for rubber balance pipe on left) - see pics
RGP750
March 08, 2017, 07:29:46 AM »
This one ??
The slide is stuck and i'm short of play time to get it out.
it's yours if yous want it.
Rich
1973 CB175
1972 CB175
1969 750 K0
Phil Ward (RIP)
March 08, 2017, 11:33:37 AM »
Thats the one Rich - I'll PM you - Thanks
Phil Ward (RIP)
March 08, 2017, 12:45:50 PM »
All now sorted thanks to RGP750 - donation made at Rich's request
Thanks again
JamesH
Reply #10 on:
March 08, 2017, 02:38:36 PM »
Good result well done Rich...
RGP750
Reply #11 on:
March 08, 2017, 02:48:16 PM »
Least i can do.
Had loads of help from here.
1973 CB175
1972 CB175
1969 750 K0
Phil Ward (RIP)
Reply #12 on:
March 10, 2017, 04:14:46 PM »
I got the carb from Rich today (Thanks Mate) - some slight differences that I need to see if they make a difference.
First the brass insert that the needle slides into (see CSML link and picture) sticks up higher than my carb - how do I get this out so I can change them over?
http://www.cmsnl.com/honda-cb750k6-four-france_model14385/needle-setjet_16012392004/#.WMKgAjuLTIU
I guess it taps out but I have tried and it seems solid (unless I'm tapping from the wrong way)
Second, when looking at the roof of the float chamber, there are 2 holes - on the repacement carb, one with a brass reducer (like a jet) and one without - see pics. My original has no brass reducer in just the 2 holes. My other carbs (1,2,3 carbs) have one reducer - so it may be somehow its fell out - or No 4 carb may not have a reducer on that model/carb run (I bought them of ebay so don't know what model there off - the CR Rep has been built from parts starting with a K2 frame I had)
Carb markings are different - mine are '064A ANH' and replacement is '657A LC1'
Once again, any help much appreciated.
PHIL
Trigger
Reply #13 on:
March 10, 2017, 07:28:40 PM »
You take the rubber duck and grab it by the neck, turning it towards the left
Phil Ward (RIP)
Reply #14 on:
March 10, 2017, 08:09:51 PM »
I think that will confuse everybody except you and me Graham!
Sorted this now (Thanks again to Graham) - the needle 'guide' drifts out from the top - I tried it from the bottom.
Second question doesn't matter now as I can now use the carb that Rich provided
CB750
