Author Topic: New member  (Read 20586 times)
Offline Tony P
Re: New member
« Reply #15 on: March 19, 2017, 07:46:57 PM »
Very funny, I will get some pics on here tomorrow after work !
Re: New member
« Reply #16 on: March 19, 2017, 08:15:54 PM »
Hi Tony.  Just up the road!
Julie - this looks OK to me (as a mere 500 owner...) https://en.wikipedia.org/wiki/Honda_CB400F
Re: New member
« Reply #17 on: March 19, 2017, 08:20:15 PM »
Haha, your right Steve, they must have changed the picture, it used to show a CB400/4 with non spoked wheels
Offline Chris400F
Re: New member
« Reply #18 on: March 20, 2017, 08:52:47 AM »
Wheels required then !
May be able to help with a front one, or just a hub if you want to rebuild with a new rim - it depends what you need.
From your earlier post does that mean that you have cast wheels?
« Last Edit: March 20, 2017, 09:24:00 AM by Chris400F »
Offline Tony P
Re: New member
« Reply #19 on: March 20, 2017, 05:00:36 PM »
Hi Chris
So here she is
Offline Tony P
Re: New member
« Reply #20 on: March 20, 2017, 05:06:02 PM »
As you can see, going to need a few bits and bobs, including a kickstart shaft !
Re: New member
« Reply #21 on: March 20, 2017, 05:44:44 PM »
They look like they're from an XS Yamaha. I had a 500 once with XS400 alloys.
Offline Chris400F
Re: New member
« Reply #22 on: March 20, 2017, 05:49:35 PM »
Pretty sure they are aftermarket, I have seen similar ones fitted before to 400's but don't know the make (maybe ERA?).
There is probably a maker's name on a spoke or rim somewhere.
Think Yamaha ones are seven spoke, not six.
There is probably a market for these if you want to get rid of them, or keep them as a period accessory - depends on how original you plan to go.
Also clocks look like Superdream.
« Last Edit: March 20, 2017, 06:06:10 PM by Chris400F »
Offline Tony P
Re: New member
« Reply #23 on: March 20, 2017, 06:09:05 PM »
I will be getting rid as I want spoked wheels as per the original.
Will start stripping her down Friday !
Re: New member
« Reply #24 on: March 20, 2017, 06:43:15 PM »
You are absolutely right Chris (as usual...)
Offline Tony P
Re: New member
« Reply #25 on: March 20, 2017, 06:53:53 PM »
Is that yours Steve ?
Re: New member
« Reply #26 on: March 20, 2017, 06:57:18 PM »
It may be a good idea to post a list of parts you're after;  some of us may be able to help you out.
Offline Tony P
Re: New member
« Reply #27 on: March 20, 2017, 07:03:27 PM »
Hi Mike, thanks for the advice, so here goes :
One seat
Two wheels
Kickstart shaft
Wiring loom
Side panels and a front mudgard
And that's before I strip the engine and carbs  !!!!!!!
Re: New member
« Reply #28 on: March 21, 2017, 12:05:36 PM »
It was mine for a few years. At the time I had three 500/4s and had to reduce down to one when I moved house.
I sold it to a local guy who wanted it for his dad!
Steve
Offline Darkness
Re: New member
« Reply #29 on: March 21, 2017, 12:23:29 PM »
Hi all
Just a quick question.
Did the 1976 400 4 come with cast wheels ?
Not unless it was one of the Harrier specials put together by one of the dealers (Mocheck?) with Lester (Or was is it CMA?) Alloys, a small nose fairing, white paint and a 2/4 seat iirc?
May have also been 460cc?
« Last Edit: March 21, 2017, 04:29:10 PM by Darkness »
CB 500 Four K1 - In more pieces than shown, but now shinier.
'93 m900 Monster in red - Original and best of breed.
'95 Cagiva Elefant 750
