Author Topic: Repeated Top yoke breakages  (Read 4862 times)
Offline paulbaker1954
« on: March 23, 2017, 03:23:23 PM »
I have now had 2 top yokes break in one year. The first time I pit it down to me forgetting to tighten it up but now I have just had another one break
Fracture occurs on the right hand fork side at the rear of the bracket
Forks are true, no looseness in steering head, handles perfectly and jus MOTD
What is going on ?
2016 Yamaha MT09 Tracer
1971 Honda CB500 Four K0
Offline mickwinf
Re: Repeated Top yoke breakages
« Reply #1 on: March 23, 2017, 03:32:14 PM »
have you fitted the special thick washer in the gap to prevent over tightening?
« Reply #2 on: March 23, 2017, 04:14:34 PM »
D washer spings to mind
« Reply #3 on: March 23, 2017, 04:41:27 PM »
Aha that explains it then👌👌👌
When I got the bike these must have been missing, I see them now on the parts list
Do I need to buy them ad special washers i.e. Does anyone know the thickness so I can use a std washer of that thickness?
Offline deltarider
« Reply #4 on: March 23, 2017, 04:42:08 PM »
D washers or use the 7mm bolts as used on the CB500/550 K2 '76. Honda had a reason for this modification...
Offline Chris400F
« Reply #5 on: March 23, 2017, 05:09:20 PM »
Found this which should help: http://www.sohc.co.uk/index.php?topic=9241.0
« Last Edit: March 23, 2017, 05:19:33 PM by Chris400F »
« Reply #6 on: March 23, 2017, 05:18:22 PM »
Ordered from DS to be safe
Bit steep at 5.50 each but better than another yoke in the future!!!
Offline Seabeowner
« Reply #7 on: March 23, 2017, 05:25:41 PM »
I found the washers on the head studs are as near a dammit. But used my 500 in ignorance for a few years. Perhaps I'm just a weakling.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
Offline Tomb
« Reply #8 on: March 23, 2017, 05:55:35 PM »
I learn something new every day on here, I have no washers in my yoke, owned it for 32 years and didn't know. No other bikes I've ever owned have these type washers, I guess I tighten them just the right amount not to cause breakages
Tom
'62 CB77 Sprinter
'70 CD175
'78 CB550 with sidecar
'80 Z50R
Offline deltarider
« Reply #9 on: March 23, 2017, 06:16:06 PM »
Quote
What model year?
« Reply #10 on: March 23, 2017, 08:55:32 PM »
Mines a 71 USA Spec  K0
« Reply #11 on: March 24, 2017, 08:07:19 AM »
Cant add anything but Crikey, the amount of Honda knowledge on this forum is stunning. Where else would you find detailed information like that. Well done guys.
« Reply #12 on: March 31, 2017, 01:27:36 AM »
Lady luck has blessed me !!
The day the yoke fractured i got a replacement off fleabay auction for £15 (i was only bidder). The seller was in York is this a member here??
Hopefully with my outrageously expensive D washer from DS all will now be sorted
