Author Topic: Piston ring compressors  (Read 2971 times)
Offline Ashdowner
« on: March 26, 2017, 10:59:19 AM »
Is it easy to use piston ring compressors when rebuilding a CB550? It strikes me that there's not much space with the barrells dropped to get the compressors out when the last two pistons have gone in.
CB550K3, CB550K1, Yamaha Midnight Star, and CA77 in 2473 pieces (at the last count)
Re: Piston ring compressors
« Reply #1 on: March 26, 2017, 11:17:34 AM »
Try using the coke can and cable tie method.
« Reply #2 on: March 26, 2017, 11:41:09 AM »
Unless it is way overbored you don't need them as there is a taper at the bottom of the liners
Offline Ashdowner
« Reply #3 on: March 26, 2017, 12:10:12 PM »
Bryan that how' I've done it (by myself) in the past on twin cylinder Honda's with a 180 degree crank without any problem but my mate who's helping me keeps telling me that compressors are essential on a 4 cylinder to avoid fiddling about with the last 2 cylinders. Think I'll tell him to shut up and get on with it.
« Reply #4 on: March 26, 2017, 12:12:27 PM »
I think Trigger and oddjob will agree that all you need is patience and a small screwdriver as the barrels will not slide down on the two fitted ones whilst you get the last two in
Offline Seabeowner
« Reply #5 on: March 26, 2017, 01:36:23 PM »
Did it yesterday on the 500 and two people make the job much easier. 2&3 at top first. Then turn engine to bring up 1 &4. As Bryan said just finger nails or rather thumb nails in my case and gently jiggling to use the taper. (and just the gentlest tap with my hand once I was sure that things were going ok.) I put a tiny amount of thin grease on the taper before I started, but maybe someone will tell me that's a bad idea. And then a dose of oil. from the top.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
