Author Topic: Oil leak at base of stator cover  (Read 5507 times)
Offline Niko
« on: March 29, 2017, 11:07:54 PM »
Hi....had the bike running tonight. When it's running it drips oil from the stator cover.
Wiped it off and it all seams dry inside.
I read somewhere about an oil seal / oil gallery in that area....?
Can someone help me out with where it's located please?
Re: Oil leak at base of stator cover
« Reply #1 on: March 30, 2017, 07:32:18 AM »
I have seen the plug fitted backwards berfore, the small pip faces outwards
Offline Niko
« Reply #2 on: March 30, 2017, 07:54:22 AM »
Thank you both very much...will check tonight
Sent from my SM-G935F using Tapatalk
« Reply #3 on: March 30, 2017, 07:56:36 AM »
Niko,
              If it is like the 400/4 DON'T start it with the cover OFF.
You will end up with oil all over the floor. (I made the mistake thinking it would be easy to clean the rotor :'()
« Reply #4 on: March 30, 2017, 08:07:08 AM »
I second that and don't even kick it over with the cover off!!
Offline Niko
« Reply #5 on: March 30, 2017, 11:28:45 AM »
Ok....cheers
Offline matthewmosse
« Reply #6 on: March 30, 2017, 07:07:41 PM »
 Has the bike been stood for a while - I had a similar leak with a usa inport engine, decided as I needed the bike for work to ignore the leak and just keep the oil topped up until I had time to fix it, after a week of the 40 mile round trip to work the leak was gone and oil level stayed right between changes.
Offline mike the bike
« Reply #7 on: March 30, 2017, 07:52:22 PM »
I know a guy who had a minor crankcase oil leak.  He didn't fix it as such; he bodged up a bit of tubing to direct the oil over his drive chain.  "cheaper than buying a Scottoiler" he said.
Offline Niko
« Reply #8 on: March 30, 2017, 09:37:36 PM »
Fixed...turns out it was weeping from the cam chain tensioner bolt and running along the barrel case....dripping off the stator.
« Reply #9 on: March 30, 2017, 10:10:31 PM »
New o ring and sealing washer required
Offline Niko
« Reply #10 on: March 31, 2017, 09:06:19 AM »
