Author Topic: Do 400/4 rear mudguards /fenders fit a cb550f  (Read 11844 times)
Offline Chris400F
Re: Do 400/4 rear mudguards /fenders fit a cb550f
« Reply #15 on: April 09, 2017, 09:24:38 PM »
My thinking/belief is that if tyre size is wider then the swinging arm is wider to allow for this and the frame tubes at the top are correspondingly wider to keep the shock mounts the same distance apart at top and bottom, but I may be wrong in this assumption.
I know when I was looking for a rack that would fit that some I looked at were too wide at the shock mounting points, being probably intended for larger bikes. Fortunately someone on here helped me out with one that was intended for the bike.
It's not easy to measure accurately in situ but the distance across the mounting points on the 400 is approx. 170mm.
Offline Seabeowner
« Reply #16 on: April 10, 2017, 09:40:39 AM »
Late 550K bare frame measured as 174mm.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
Offline Darkness
« Reply #17 on: April 10, 2017, 03:03:08 PM »
Isn't the 3.5 X 18 rear tyre on a 400/4 (Or CB360 G5) the same width as the 3.5 X 18 tyre on a CB500-4?
Though I used to prefer a 4.25/85 X 18 TT100 on the 500.
CB 500 Four K1 - In more pieces than shown, but now shinier.
'93 m900 Monster in red - Original and best of breed.
'95 Cagiva Elefant 750
Offline Chris400F
« Reply #18 on: April 11, 2017, 10:22:37 AM »
I think it is true that the 400 has things like tyre sizes in common with smaller models such as the 250/360, whereas 500 and up have larger section tyres.
I'll hold my hands up - I stand corrected.
Maybe it's just a case of whether the mounting holes line up OK.
