Author Topic: Oil Filter thread size  (Read 4026 times)
Offline captaink
  • Old racers never die. ' they just go faster '
« on: April 06, 2017, 11:43:17 AM »
Hi , does anyone know the thread size for the oil filter bolt that screws into the lower casing.
I need to clean the thread, so want to order a tap to suit
Regards Keith
CB750 1977
CR750 Replica
Norton Manx's 1947 & 1956
Norton CS1 1930
Norton International  1934
Norton 16H 1924
Norton Model 18 1929
Norton Commando / Colorado Norton Works
Triumph 1947 GP Replica
Triumph Bonniville 1967
BSA Goldstar Daytona 1956
Harley Duo Glide 1961
The Rickman project
And the CR dick Mann replica project
Sold a few of the Bikes so only got these left
Gt40...Car I know
E type fhc 1964... Car I know
" Greedy I Know
Offline captaink
Re: Oil Filter thread size
« Reply #1 on: April 06, 2017, 12:28:48 PM »
Thanks, but I think that's too small, have been told M20 x1.5 which sounds correct but thought id ask others
CR750 Replica
Norton CS1 1930
Norton 16H 1924
The Rickman project
Gt40...Car I know
" Greedy I Know
Offline Phil Ward (RIP)
« Reply #2 on: April 06, 2017, 01:14:56 PM »
Just measured a spare - its m20 x 1.5
Sent from my MotoG3 using Tapatalk
« Reply #3 on: April 06, 2017, 06:44:34 PM »
Why not just buy a new bolt ?
Offline hairygit
« Reply #4 on: April 06, 2017, 07:03:37 PM »
My thoughts exactly, with such an engine life critical part, if the thread is damaged, heat and vibration will only make it worse, and the engine would not last long if it started leaking while riding it, if you survive the inevitable accident caused by oil spewing on the road directly in line with the rear wheel. Seen it happen on a 400/4 many years ago.
Offline hairygit
« Reply #5 on: April 06, 2017, 07:07:02 PM »
That said, I take it that the thread in the crankcase is dodgy if you're looking for a tap, do it properly with a Wurth insert, damaged threads in alloy will not hold for long!
« Reply #6 on: April 06, 2017, 07:22:18 PM »
I agree Hairy - and doing an insert on a thread that size with hand tools may not be that accurate - probably need a machine shop to carry out that job?
Offline hairygit
« Reply #7 on: April 06, 2017, 08:03:54 PM »
  To be 100% safe about it, yes, a good engineering firm will be needed.
Offline Tomb
« Reply #8 on: April 06, 2017, 08:34:48 PM »
If it helps find a tap, electrical conduit size is M20 x 1.5
Tom
'62 CB77 Sprinter
'70 CD175
'78 CB550 with sidecar
'80 Z50R
Offline captaink
« Reply #9 on: April 17, 2017, 05:53:54 PM »
Thanks for the replies.
Got an M20 x 1.25 to clear the thread.
The thread wasn't damaged but the process of aqua cleaning it, it needed clearing and as I did all the 6mm threads in the casing it was worth doing this one as well.
Because most of the threads had bolts put in some 40 years ago they should be ok but the oil filter has most likely been apart a few times , so could suffer from wear.
If it was worn I would most likely have fitted a spin on oil filter adaptor as supplied by Cycle X. which would eliminate the need to remove the adaptor fitting from the casing.
I may even fit one anyway, but not sure !
CR750 Replica
Norton CS1 1930
Norton 16H 1924
The Rickman project
Gt40...Car I know
" Greedy I Know
