Author Topic: 750k7, carb overflow tubes; easy replaced???  (Read 1890 times)
Offline Mag1
« on: April 17, 2017, 10:56:39 AM »
good day all, well i had my engine running yesterday for the first time, and boy was it good to hear it after all this time rebuilding. she runs great. this was a test run before i install everything else like airbag, oil breather pipes etc. i had the carb floats measured at 14.5 as recommeded, all new parts in carbs, apart from overflow tube and floats these are fine at the moment, however when filling the carbs from remote fuel tank two carbs overflow, so 1) i need to complete the fuel level tube levels on each, which i don't mind doing, and 2) maybe my overflow tubes are split, i need to inspect these closely. if i do need new overflow tubes in 1 or two of the carbs how easy is this and where do i get just the tubes for PD carbs?, is there a remedy to fix insitu? maybe some resin?. apart from that she ran great, but ran on half choke, which i presume is because i have no air filter box installed at the moment and the i need to balance the carbs.
Honda CB750K7 1977
Yamaha XS750e 1977
Vespa 100 (being restored)
Offline MarkCR750
Re: 750k7, carb overflow tubes; easy replaced???
« Reply #1 on: April 17, 2017, 11:55:40 AM »
I had a split tube on mine, a hairline crack running the length of the brass tube, someone on the forum kindly gave me a replacement bowl, I guess you can pull the tubes out and replace but I've not heard of anyone doing it, if they are cracked it may be possible to solder them?, I'm sure the choke being needed is down to the airbox not being on.
Triumph Scrambler 1200X
CCM 604 dual sport
1977 K7 CR750
Ducati 900SS
James Captain 197 x2
Norman Nippy 50cc
Sir J.Stewart.
Offline Mag1
« Reply #2 on: April 17, 2017, 12:03:50 PM »
Thanks Mark, was thinking of soldering or maybe POR15 to paint over them, but that's a last resort. I have to carb float check first, then recheck them. Does not look easy to replace these overflow tubes, fragile I suppose.
Honda CB750K7 1977
Yamaha XS750e 1977
Offline kettle738
« Reply #3 on: April 17, 2017, 12:22:19 PM »
You can solder them....it's slightly awkward, but a fibreglass pencil to clean it up makes the job easier and low temperature modellers solder means much less heat involved.....a mini gas torch is perfect for the job.
Mick.
