Author Topic: Head gasket sealing?  (Read 11035 times)
Offline onethumb
« on: April 23, 2017, 04:22:51 PM »
Right my new OE head gasket has arrived so I'll be fitting it sometime this week ( got to get some oil seal metal tubes). Due to the last one being slightly out I want to cover all bases as it's costing me more than I can really afford now.
I've spoke to several different people and want to know what people here think about using copper slip or blue hyolmar or nothing. Ideas ?
"20 in a 40 is not safe driving"
Offline hairygit
Re: Head gasket sealing?
« Reply #1 on: April 23, 2017, 04:34:03 PM »
DRY, and totally clean mating faces, OE head gaskets have a sealant sandwiched inside, which squeezes out as the head is torqued, making it an excellent seal.
Offline Skoti
« Reply #2 on: April 23, 2017, 05:02:31 PM »
I've never used sealer whatsoever anywhere with OE gaskets on Honda motorcycle engines.
Make sure mating surfaces are spotlessly clean and dry and also oil free and your good to go.
Have fun!
Skoti.
Skoti
1976 Honda CB750F1
Offline yozzer74
« Reply #3 on: April 23, 2017, 07:46:05 PM »
Just built mine back up today didn't use anything on it also didn't use any sealer on rubber pucks .as recommended by a few people
Offline onethumb
« Reply #4 on: April 23, 2017, 07:49:38 PM »
Yozzer did you put the 4 knock pins back in with the doughnut seals. Glad it's back together. Nice one.
Offline yozzer74
« Reply #5 on: April 24, 2017, 04:36:18 AM »
Yes I did
Offline onethumb
« Reply #6 on: April 24, 2017, 07:13:50 AM »
Glad I ordered a replacement now.
« Reply #7 on: April 24, 2017, 10:12:37 AM »
No sealant used or needed on mine, but I did put a touch around the rubber pucks for peace of mind, and because Mark Paris said so, it was leaking from there before it came apart. All dry now.
« Reply #8 on: April 24, 2017, 11:18:49 AM »
I've never used any sealant on a 750 engine but I've always used genuine gaskets and made sure that the mating surfaces were super clean.
Offline onethumb
« Reply #9 on: April 24, 2017, 12:12:42 PM »
Thanks.
I'm thinking weather or not to do the piston part while I've got it stripped. It was OK and dry before so thought it would be ok but I've read that people are doing this at the same time as the head because of movement. Any thoughts?
« Reply #10 on: April 24, 2017, 01:44:18 PM »
In business we would never do just a head gasket always base as well to guarantee good sealing, when you have to remove the engine to do anything and the cost of the head gasket as well it was a no brainer to us
Offline Mag1
« Reply #11 on: April 24, 2017, 11:35:48 PM »
Have seen people using some bond to glue the gasket, why I don't know as this can squeeze into the engine and cause blockages. As others have stated, clean and gasket only needed.
Honda CB750K7 1977
Yamaha XS750e 1977
Vespa 100 (being restored)
Offline onethumb
« Reply #12 on: April 25, 2017, 06:59:37 AM »
Thanks. Info always appreciated.
Offline Phil Ward (RIP)
« Reply #13 on: April 25, 2017, 02:01:13 PM »
The using of extra sealant comes from 'Hondaman' on the sohc.net site. It covers the earlier heads/barrels that didn't use the extra dowels/seals. It recommends thicker o rings and sealant in certain area's. I haven't got the .net forum links but kept an extract for future reference - see below.
Extract from sohc.net Hondaman post
'The OEM ones were Buna N (durometer 65-75). Those are real common. Make sure the size is 2.5 x 12mm, not the undersized ones found in some gasket kits lately. I just bought some 2.5x12 in both Buna and Viton, if you can't find any there.'
Not giving an opinion on the need for sealant but just quoting where the use of sealant may have come from - although I used the larger o ring as above on my K2 and its leak/mist free
« Last Edit: April 25, 2017, 02:06:12 PM by philward »
Greebo
  • Guest
« Reply #14 on: April 25, 2017, 02:19:11 PM »
according the sohc specialist that built /restored my bike says using any kind of sealant is a definite No !!
One guy who took no notice of Steves advice insisted it was used on his rebuild & learned the hard way when the top end seized & he needed a new Cam, apparently a micro amount of sealant found its way & blocked the oil feed to the top end.
Obviously a new gasket is needed when rebuilding [no sealant] & the oversized O-Rings is the only way to go.
PS... I know I have got this story correct
« Last Edit: April 25, 2017, 02:20:57 PM by Greebo »
