CB350/400
Gear lever circlip groove wear?
Topic: Gear lever circlip groove wear? (Read 4007 times)
Clem2112
Midlife
SOHC Expert
CB400F1 1976 R1200GS 2016 Matchless G80 1955
May 20, 2017, 07:14:50 PM »
For the second time since the bike's rebuild the circlip parted company with the shaft today.
Just made it down a slip road in second luckily.
I may have used a non standard circlip burpt it looks like the groove in the shaft is a bit shallow?
Anyone here come up with a better way to retain the lever in this setup?
Nurse Julie
Re: Gear lever circlip groove wear?
May 20, 2017, 08:42:35 PM »
I had exactly the same thing happen last summer on my 400/4, half way around quite a fast corner !!. Put a standard size circlip back on and fingers crossed, hasn't come adrift again. But, like you say, the groove does seem very shallow.
mike the bike
CB400F, Royal Enfield Interceptor.
May 20, 2017, 08:45:58 PM »
I cut the groove deeper with a hacksaw, it hasn't fallen off since.
Clem2112
Midlife
SOHC Expert
May 20, 2017, 11:44:53 PM »
That idea crossed my mind too , after a beer !
It would be a really tricky job to re plunge cut the groove on a lathe after all.
Cheers.
PatM
SOHC Member
2001 R1, Triumph 1200 and the little 400/4!
May 21, 2017, 12:37:38 PM »
Easier that stripping it off to mount it on a lathe! Dremel might assist, but junior hacksaw would be kinder and easier- less chance of going too far!
mike the bike
May 21, 2017, 05:12:35 PM »
I had a closer look at mine; It's been a while since I modified it but I drilled through the shaft and fitted a split pin.
Clem2112
Midlife
SOHC Expert
May 22, 2017, 09:48:45 AM »
I guess a washer and split pin or R clip would be option 2.
First find a sharp 1.5 mm drill
Clem2112
Midlife
SOHC Expert
May 24, 2017, 09:02:20 PM »
Drilled it. Stainless washer fettled to fit the pivot and retained with a split pin.
I defy it to fail again !
Nurse Julie
May 24, 2017, 09:16:44 PM »
I think I should do the same modification sometime, it's really not a nice feeling when you go to change gear and there is nothing to change gear with !!!
Last Edit: May 24, 2017, 10:50:28 PM by Nurse Julie
CB350/400
