Author Topic: CB550K3 clutch shims  (Read 2631 times)
Offline Ashdowner
« on: June 10, 2017, 10:33:57 PM »
Just taken my K3 clutch apart and found two very thin steel washers behind the retaining circlip that holds the basket on the shaft. Looked it up on CMSNL and found that there are three thicknesses of these washers (Item 15 on the clutch exploded view and part no 90458323010 is the 0.1mm thick option). So they obviously act as shims, but how tight should they be holding the clutch on the shaft? Is there some specified gap between the circlip and the shims? My clutch does move a fraction up and down the shaft and I wonder if this contributes to the famous CB550 clutch rattle.
CB550K3, CB550K1, Yamaha Midnight Star, and CA77 in 2473 pieces (at the last count)
Offline Ashdowner
Re: CB550K3 clutch shims
« Reply #1 on: June 11, 2017, 06:27:38 AM »
Thanks for that OJ. On that basis mine is definitely too loose. I'm going to Holland on a visit next week so I'll get some delivered to my sisters.
Offline Ashdowner
« Reply #2 on: June 17, 2017, 08:56:57 AM »
I believe that they are mail only.
