Author Topic: Starter solenoid 550f  (Read 10973 times)
Offline bomber
« on: July 02, 2017, 03:10:15 PM »
I finally got all the bits together!
Went to start the engine and all that happens is a blowing a main fuse.
I think I have put together cabling in correctly on the starter solenoid.
I have 2x red cables one form battery and second for the loom on one side and on left there is black original cable going to the starter motor.
there are also two short cables going to the loom which color match the solenoid so I think that is ok.
Could anyone be kind and took a picture of the wiring around the solenoid?
Any thoughts?
One step forward, two steps backward...
Honda CB550F 1976
Offline BigAl (Alan)
    • www.alans-electrics.co.uk
Re: Starter solenoid 550f
« Reply #1 on: July 02, 2017, 03:48:02 PM »
I have attached an image of the harness CB550F solenoid connections, small picture which may not be very clear
Solenoid connection 2 wire (Yellow/red socket) & (Dark green/red plug)
Safety switch 2 wire (Dark green/red +) & (Light green/red -)
Current bikes:-
Honda CB750 K4 (1974) USA
Honda XL500S (1980) UK
Honda CD175 sloper (1968) UK
Honda CB1100A (2013) UK
Offline bomber
« Reply #2 on: July 03, 2017, 09:49:51 PM »
Thank you BigAl for response.
I dont have the original solenoid, mine is a nighthawk 650 model, which i got as a replacement of a car solenoid which was fitted by previous owner.
Looking at your post the connections are clear but I wonder if fitting a solenoid 180 degrees(as it is round) will mean that i'm fitting the thick cable from starter motor on opposite side -wrong side. would that make the fuse to blow? does it matter which side you plug the thick positive cable to it?
Many thanks
« Last Edit: July 03, 2017, 10:28:55 PM by bomber »
Honda CB550F 1976
« Reply #3 on: July 03, 2017, 10:24:13 PM »
I was just reading this post with interest, went to look at the attached PDF......did you realise you have put your London Congestion charge bill on as an attachment? 😃😃😃
Offline bomber
« Reply #4 on: July 03, 2017, 10:29:58 PM »
Thank you!
Honda CB550F 1976
« Reply #5 on: July 03, 2017, 10:31:55 PM »
Thank you!
No problem.
Offline bomber
« Reply #6 on: July 03, 2017, 10:50:34 PM »
So here it is pic of my solenoid in stead the congestion charge...
Should I swap it 180 degrees?
Honda CB550F 1976
« Reply #7 on: July 04, 2017, 05:55:06 AM »
You. can, but it shouldn't make any difference as the heavy starter cable isn't fused.
« Reply #8 on: July 04, 2017, 08:13:48 AM »
The wiring depends on the year and type of the RH switch.
Early ones you have a black power wire to the solenoid and the other small one goes via the loom and headlamp to the RH switch where it is earthed to the bars when you push the button
Later ones have one wire at the solenoid earthed (Via the safety interlock i think) whilst the RH switch button provides power via the headlamp and loom so if you got a mix n match you could be going straight to earth with power when you press the button.
You need to inspect the RH swith to see what it does then work from there
« Reply #9 on: July 04, 2017, 08:12:54 PM »
As previous posts, I do not think that the orientation of the heavy duty starter motor connections would blow the main fuse.
The CB550K had a 2 wire starter switch as the CB550F has a 3 wire starter switch. You may need a CB550F wiring diagram
If it helps the Clymer manual (code M332) only covers the earlier CB550K wiring.
Current bikes:-
« Reply #10 on: July 04, 2017, 11:29:32 PM »
A starter solenoid is one of the easiest things to wire up - almost as easy as a light bulb.  No circuit diagram needed.
Starter goes to one big terminal, 12V goes to the other big terminal and one of the small terminals
Red/yellow connects to the other small terminal.
You may have to swap the small terminals over to get it to go.
No, it won't blow the fuse.
Offline bomber
« Reply #11 on: July 09, 2017, 09:56:15 PM »
Thank you for replies.
Still no bloody clue why the main fuse keeps blowing I bet it is something obvious...
I wonder if there's a way of having a fuse which I can re-set it in stead blowing new one each time, so I can test what component is messing me about.
Many thanks!
Honda CB550F 1976
Offline Norniron
« Reply #12 on: July 09, 2017, 10:01:21 PM »
Wot size is the fuse Bomber?
1977 400 cafe
1972 500/4
2013 triumph STR675
Offline bomber
« Reply #13 on: July 09, 2017, 10:22:25 PM »
15 amp glass type, i have seen blade type you can re set
Honda CB550F 1976
Offline Norniron
« Reply #14 on: July 09, 2017, 10:24:40 PM »
Just use 15amp fuse wire to test it.
Saves looking for glass fuses
1977 400 cafe
1972 500/4
2013 triumph STR675
