CB750
Fork seal - damper bolt removal?
3
Topic: Fork seal - damper bolt removal? (Read 9361 times)
zebedee85
Newbie
Re: Fork seal - damper bolt removal?
Reply #30 on:
September 01, 2017, 11:56:59 AM »
Well - the operation was a success, though now I'm getting some stiction. I was a bit over zealous with the fork oil quantity so letting them drain a bit might fix it. No weeping though.
zebedee85
Newbie
Reply #31 on:
September 01, 2017, 10:37:01 PM »
Too much fork oil - removing approx 10cl both sides fixed stiction.
Trigger
Engines built on reputation, not advertising.
Reply #32 on:
September 02, 2017, 07:42:14 AM »
When you use the drain bolt, it will still leave oil in the tube so, keep a eye on the measurements
3
CB750
