Author Topic: CB125T2 from 1980  (Read 37890 times)
Re: CB125T2 from 1980
« Reply #15 on: September 13, 2017, 10:27:41 AM »
doing really well,
  please continue to post pics with updates
Offline peteuk
  • Honda CB550f
« Reply #16 on: September 13, 2017, 10:01:14 PM »
Hi. I've got the chance of a cb125t engine for the bike from a 1988 bike. Mine is a 1980 bike and was wondering if anyone could tell me if it would be a direct fit or a suitable replacement. Thanks
Offline hairygit
« Reply #17 on: September 13, 2017, 10:43:04 PM »
You would need to do quite a bit to get it running in your frame. It may well fit physically, but your bikes electrics are 6 volt and set up for kickstart only. The later engine you have bee offered will be 12volt, and electric start only, no kick start option. Plus you would need to make a loom to suit the cdi setup as your frame uses points ignition. Not insurmountable, but a lot of grief and fair bit of expense. And for less bhp than your original engine would have!
« Reply #18 on: September 14, 2017, 10:17:15 AM »
The engine from a honda cb200 benly from the same period was very similar looking with the same style rocker cover if i remember correctly....
Offline peteuk
  • Honda CB550f
« Reply #19 on: September 14, 2017, 01:25:00 PM »
Wow thanks for the info. I forgot about the reduced bhp too. I think I'll hang on and wait for a more suitable engine then. Thanks again
« Reply #20 on: September 14, 2017, 03:30:14 PM »
Keep posting as this is the type of thing that fascinates me, the idea of a bike appearing from a pile of parts is great, it's nice to see it progressing.
Offline peteuk
  • Honda CB550f
« Reply #21 on: September 15, 2017, 10:52:07 PM »
Cheers Dennis, the tank is off and is currently going through the derusting process of the inside then it gets lined and i'll be sending it to a mates for a paint job. i was going to do everything myself but ive decided to let someone who knows what they're doing tackle the paintwork. i've also got quite a few parts on order..handlebars, seat, brakes etc. Still trying to source an engine. Theres one on ebay but the seller says it won't turn over right so not sure if i want to invest in that one. I may do cos they're like rocking horse poo to get hold of. Anyway i'll post some more pics soon when its looking a bit more together.
Cheers everyone.....Pete
Offline matthewmosse
« Reply #22 on: September 16, 2017, 06:55:26 PM »
Do a bit bit of research, if the cm125 rebel can donate any engine internals, I have a decent lot of bits less a crank off a crashed bike, cases snapped in half, crank bent but otherwise looked ok. If the one on eBay won't turn over it's a fair chance the piston or bore have got rust, very often the rest is ok, probably worth a gamble as at least you have a starting point, provided the delivered cost is acceptableof course.
Offline peteuk
  • Honda CB550f
« Reply #23 on: September 17, 2017, 05:20:39 AM »
Thanks matthewmosse, the sellers reply when I asked him if it turned over, said that it turned over 350 degrees one way then got stuck then would turn 350 degrees the other way????. I think he possibly meant 360 degrees ie a full rotation but I was thinking it's possibly a bent valve or something.
Any way, he's located 150 miles away from me but I don't mind the round trip to collect if it's worth getting.
Offline peteuk
  • Honda CB550f
« Reply #24 on: September 17, 2017, 12:32:48 PM »
Hairygit, regarding your earlier message:-
Thing is the bike came without an engine so therefore as long as it fits in the frame, am I right in thinking I just need to make sure everything is 12volt ie lights, regulator, battery etc. Sorry if I sound like I don't have a clue but basically that's not far off the truth. Cheers
Offline hairygit
« Reply #25 on: September 17, 2017, 01:07:08 PM »
Well, yes you can convert to 12v, but you will need a lot of additional parts, and a considerably larger battery, switchgear with start button, solenoid, cdi unit, probably easiest to use the harness from a 12v bike, then regulator, rectifier, coils, flasher unit, horn and all bulbs. I had the impression you were trying to keep it fairly original, but as I said, not insurmountable problems, but a fair bit of aggro and expense.
Offline peteuk
  • Honda CB550f
« Reply #26 on: September 18, 2017, 09:57:17 AM »
Hiya Hairygit, no im not keeping this one original, I did with the cb550 but this ones having black and white paintwork, cafe seat etc etc. As for all the parts you mention, I didnt get them with bike anyway. Engine, carbs, electrics, rectifier, battery all missing so i would have to buy them anyway and from looking round, 12v supplies seem much easier, and cheaper, to come by
Offline peteuk
  • Honda CB550f
« Reply #27 on: October 04, 2017, 10:58:22 PM »
Hi, I will be posting some more pics soon and I have managed to get a 1978 unrestricted 125t engine which is a bit of a bonus. The engine was missing a few parts, ie points plate and points, inlet stubs and carbs etc. Anyway I've got these parts on order but I'm puzzled by the points, in particular the condensers. On previous bikes I've had the condensers were bolted to the points plate underneath and attached to the points. Not so on this bike and I've searched everywhere including the manual and I can't workout where they're supposed to go or where they're supposed to attach to (which wire etc). Any help with pictures would be greatly appreciated. Thanks
Offline RGP750
« Reply #28 on: October 05, 2017, 06:56:21 AM »
I'm picking up 2 bikes from my Father in laws after work tonight ,both Hondas
Both are 125's i seem to remember a twin and a single i think.
They have been left outside in an old green house for some years s not sure what i am going to find.
I would like to get one of them going for him (he is now in a home)
but may move the other one on .
If it is the same as yours may be of use for reference.
Watch this space
1972 500/4
1973 CB175
1972 CB175
1959 BSA Super rocket
1927 960cc Matchless 'v' twin
1969 750 K0
Offline Yoshi823
  • Biker to the bone...
« Reply #29 on: October 19, 2017, 08:40:25 PM »
Hi PeteUK
The condensers for the points ignition are mounted on the battery box. Not sure why. I remember on my '72 CB125s that I first rode in '75 had the single condenser under the points cover, but there's no room on the CB125T2.
Bikes...they're in the blood.
Yamaha R1 2001
Yamaha FZR1000R EXUP 1990
KTM 450 EXC RFS 2004
Honda XR400R 1997
Honda CB125T2 1980
Yamaha FJ1200 3XW 1991
