Author Topic: CB125T2 from 1980  (Read 35175 times)
Offline Yoshi823
  • Biker to the bone...
Re: CB125T2 from 1980
« Reply #30 on: October 19, 2017, 08:47:10 PM »
Unfortunately photobucket have decided to change their Ts&Cs so my pics are no longer showing unless I pay.
But my post that I started a while ago is here when I was rebuilding my CB125T2. It's still not finished & even less likely to get done anytime soon as i'm going to be a grandad in February & my efforts & spare time are being used in a different direction atm.
http://www.sohc.co.uk/index.php/topic,2763.0.html
Bikes...they're in the blood.
Yamaha R1 2001
Yamaha FZR1000R EXUP 1990
KTM 450 EXC RFS 2004
Honda XR400R 1997
Honda CB125T2 1980
Yamaha FJ1200 3XW 1991
Offline peteuk
  • Honda CB550f
« Reply #31 on: October 20, 2017, 06:36:06 PM »
Hi Yoshi, I would have loved to see those pics but as you say photobucket are not allowing it now unless you pay
Offline peteuk
  • Honda CB550f
« Reply #32 on: October 20, 2017, 06:51:29 PM »
I got the engine for the bike and this is what it looked like
Offline peteuk
  • Honda CB550f
« Reply #33 on: October 20, 2017, 06:55:14 PM »
And this is now
Offline peteuk
  • Honda CB550f
« Reply #34 on: October 20, 2017, 07:03:53 PM »
Got the paintwork done. I'm still looking for handlebars so using a sawn of broom pole at the mo.
Offline peteuk
  • Honda CB550f
« Reply #35 on: October 20, 2017, 07:09:05 PM »
For those who are wondering about the back end looking out of place, and i'm one of em, i'm removing the rear sissy bar (if that's what it's called), and shortening the inner black mudguard. I'll then need to do a bit of welding for the seat to fit correctly. Watch this space cos i'm no welder but i'll give it a go.
Offline MarkCR750
« Reply #36 on: October 21, 2017, 06:24:44 PM »
If you leave the bar on the back Pete you could place one foot on it and pull amazing wheelies, just sayin 😗
Triumph Scrambler 1200X
CCM 604 dual sport
1977 K7 CR750
Ducati 900SS
James Captain 197 x2
Norman Nippy 50cc
Sir J.Stewart.
Offline peteuk
  • Honda CB550f
« Reply #37 on: October 21, 2017, 06:30:14 PM »
 It's a thought but my wheelie days are long past.
Offline MarkCR750
« Reply #38 on: October 21, 2017, 08:16:41 PM »
Ha, I wouldn’t dare try one nowadays, mainly because I’ve seen others do it and fail, and there’s definitely no more effective way of making yourself look a complete plonker!.
CCM 604 dual sport
1977 K7 CR750
Ducati 900SS
Norman Nippy 50cc
Sir J.Stewart.
Offline peteuk
  • Honda CB550f
« Reply #39 on: October 22, 2017, 06:52:52 PM »
Now got the engine in and handlebars on so I've ditched the broom handle.
I'm still looking for any information regarding placement of the condensers. On other bikes i've had/got, they were placed underneath the points but not on this bike. The schematic shows it up near the battery housing but if any one anything more specific with photos that would be a great help. Thanks
Offline MarkCR750
« Reply #40 on: October 22, 2017, 08:55:23 PM »
Thats looking smart Pete, better than I thought it would actually 👍
CCM 604 dual sport
1977 K7 CR750
Ducati 900SS
Norman Nippy 50cc
Sir J.Stewart.
Offline peteuk
  • Honda CB550f
« Reply #41 on: October 29, 2017, 07:13:56 AM »
Hi, so I've  got the condenser sighting sorted and I'm on with the electrics. As I mentioned earlier, electrics are not my strong point. I have got power to the points (Tested with a circuit tester bulb) but no spark at the plugs. Any ideas anyone. Cheers
« Reply #42 on: October 29, 2017, 08:02:26 AM »
You can look at the points as a switch to earth,  so when they are open the earth is disconnected.
If you supply a bulb from batt + and earth through the points it should be alight with points closed and go off as points open.
One of the most common problems is with the little insulating washers where the leads connect to the points,  if not in the right place then the lead is earthed all the time and gives no switching.  So obviously no sparks.
Nice work on it,  bike looks really good.
Offline mike the bike
« Reply #43 on: October 29, 2017, 08:20:34 AM »
On a similar note, there should be 12V on one side of the coil and a fluctuating 12V (12. 0. 12. 0  12........)    on the others side, caused by the points opening and closing.   This can be checked while turning the engine by hand.
Offline peteuk
  • Honda CB550f
« Reply #44 on: October 29, 2017, 09:07:44 AM »
Hi, thanks for the replys. I do have power to the points and when doing the timing, the bulb from the test light goes out and comes on as it should when the the crank is turned. As for the 12v mentioned, the coils are 6v. Cheers
