Author Topic: faulty oil pressure sensor.???  (Read 7940 times)
Offline matthewmosse
Re: faulty oil pressure sensor.???
« Reply #15 on: September 20, 2017, 09:58:03 PM »
So far I have only ever had that light come on due to a dodgy sensor switch. I've had a couple do that, on one the switch actually started spraying oil out of the top too. At least it made diagnosis easy. You can hear on the cb550 when the oil supply to the head is poor, rattles like a can of old bolts being shaken up. Inexperienced owners might not spot it, if the bike arrived sounding that rough like my k3 oil slick did, but once your used to a decent sohc motor running nicely with a civilised exhaust it's fairly clear from the engine note that all is not well pretty soon. Trouble is I like my un civilised exhausts.....
Offline Woodside
« Reply #16 on: September 20, 2017, 10:51:21 PM »
ok heres the story...
the oil light never came on even when ignition was on...
wiring ok and would come on when i hot wired it...
put a spare (old one from an engine i have kicking about under the bench)in
riding to mot 5 ish miles...last half mile light was glimmering on...under 2000 rpm above dimmed off...
should have the new one here in a day or so i will pop ot in and see...
the bike is really quiet probably the quietest i have had  no rattles or knocks and very happy under load
Offline Woodside
« Reply #17 on: September 21, 2017, 05:34:14 PM »
well switch fitted ...20mins running and all good but i wont really know untill i get out  for a ride...tipping down here so probably/hopefully the weekend....fingers crossed
« Reply #18 on: September 21, 2017, 05:45:25 PM »
Hopefully if the oil lights not on now when at low revs / idling, the new switch has resolved the problem Jason. Fingers X'd.
Offline Woodside
« Reply #19 on: September 21, 2017, 06:21:56 PM »
everything crossed..
it happened after 5 or so miles ...i wouldve thought 20 mins at idle would warm it up abit quicker and some
