Author Topic: Misfires above 4,500  (Read 61140 times)
Offline jon stead
« on: September 24, 2017, 10:48:22 PM »
Stumped again.
Engine still ticks over nice and rides nice at low revs but doesn't pull above 4500 rpm. Number 3 plug was sooty, so I put the original carbs back on, hard to say if better or not, but plug 3 still sooting  up. So unlikely the same fault is with both sets of carbs.
Checked Boyer Branson electronic ignition advance is ok, I.e. Full advance at 4,500 rpm.
There's a new set of D7 plugs in, gapped correctly. Valve timing is correct and valve clearances are correct.
Now looking at electrics again. Confirmed plug cap resistance is correct and have also exchanged cap 3 and 2 for each other. If number 2 plug soots up then it's the plug cap at fault. Will check tomorrow. Also going to check all electronic ignition wiring tomorrow, coils and ht leads.
Edit: Corrected cylinder numbers - sorry, Chris
« Last Edit: October 13, 2017, 08:48:01 PM by jon stead »
Offline kevski
Re: Misfires above 4,500
« Reply #1 on: September 25, 2017, 08:16:20 AM »
Do you have both resistor caps and plugs, if so that would most likely be the problem.
« Reply #2 on: September 25, 2017, 09:49:45 AM »
Jon - stupid question but check your main jets. I had an almost identical issue on a 750 recently. Previous owner had drilled out the main jets to prob 150-160 (should have been running 120's) and it was the last thing I thought to check (the mains were stamped 120). May be a red herring but worth looking at when you have the carbs off...
« Reply #3 on: September 25, 2017, 09:50:56 AM »
Ignore the above - didn't see that you'd tried two sets of carbs with same symptoms...
Offline jon stead
« Reply #4 on: September 25, 2017, 10:12:27 AM »
Thanks. It's got 5k ohm resistor caps and non resistive plugs
Offline jon stead
« Reply #5 on: September 25, 2017, 10:13:29 AM »
Thanks. Jets are correct in both sets of carbs I've got. Fault stays the same, whichever set if carbs I've got on.
Offline jon stead
« Reply #6 on: September 25, 2017, 10:17:00 AM »
It's all stop again :-(
Checking the plugs to see if the fouling had moved to number 2 after swapping the plug caps yesterday, and I've gone and stripped the threads on number 2 cylinder. It's always been stiff to screw in and out but now it's given up the ghost. Sigh.
Question: can a helicoil repair be carried out in situ?
« Last Edit: October 13, 2017, 08:49:45 PM by jon stead »
Offline Ashdowner
« Reply #7 on: September 25, 2017, 10:52:57 AM »
Yes someone I know just had it done. It's not a helicoil but a solid insert, and it's done very carefully so no crap ends up in the barrel..  dougie@thethreadmaster.co.uk  07775510166 is a guy in Hampshire who did it for him in Sussex, but there will be someone local to you who can do it.
« Reply #8 on: September 25, 2017, 11:53:34 AM »
« Reply #9 on: September 25, 2017, 12:18:56 PM »
Be careful, its going to be very difficult if not impossible to avoid getting swarfe in the cylinder when fitting any kind of insert. Will need to be vacuumed out somehow.....
« Last Edit: September 25, 2017, 12:27:48 PM by Rob62 »
« Reply #10 on: September 25, 2017, 01:02:04 PM »
As far as I can remember the guy heavily greased the tap.
Removed the exhaust header and opened the exhaust valve.
At the same time he did the tapping he was blowing air into the head via the exhaust port!
Offline kevski
« Reply #11 on: September 25, 2017, 01:07:58 PM »
Best quick fix is timesert not cheap, better fix is to have an ally insert made up, my Z1000 has all four done, and were done by a chap on the Z1 owners club who goes by the name of buzzard, even more expensive but beautifully done.
« Reply #12 on: September 25, 2017, 01:17:11 PM »
Yes, that was the one I posted the link to above.
Offline jon stead
« Reply #13 on: September 25, 2017, 03:55:00 PM »
Thanks all for your input.
I've ordered my kit up, insert rather than helicoil, and I already knew about using grease to catch the swarf. I like the idea of blowing air through the open exhaust valve. I was just going to fashion a thin tube on the end of my Henry vacuum cleaner and have a good suck around inside the cylinder before firing up.
Offline Tomb
« Reply #14 on: September 25, 2017, 04:29:32 PM »
Tom
'62 CB77 Sprinter
'70 CD175
'78 CB550 with sidecar
'80 Z50R
