CB350/400
Spark plug Caps
Topic: Spark plug Caps (Read 2213 times)
watty51
Spark plug Caps
November 11, 2017, 04:30:13 PM »
Does anyone know if the Spark plug caps from David Silver are 5000ohm suppressed
www.davidsilverspares.co.uk/CB350-FOUR/part_28361
Im just fitting a Boyer Bransden Electronic Kit 00289 and the fitting guide says the caps must be to this spec.
Many Thanks
Seabeowner
Re: Spark plug Caps
November 11, 2017, 04:39:31 PM »
The 05 is 5kohms, so yes.
The NGK plug catalogue is here:
https://www.ngkpartfinder.co.uk/files/NGK_Spark_Plug_Covers.pdf
1971 CB500K0 Candy Jade Green or Candy Gold
1973 CB500K1 Candy Ruby Red
1975 CB550F1 Shiny Orange
watty51
Re: Spark plug Caps
November 11, 2017, 04:53:24 PM »
Thanks for the quick reply.
Thought the VD05F partcode had something to do with it.
Just checking
kevski
Re: Spark plug Caps
November 11, 2017, 07:49:33 PM »
Do not use resistor plugs with these caps it will create bad running.
watty51
Re: Spark plug Caps
November 11, 2017, 08:06:54 PM »
I am using NGK D8EA Plugs at the moment. Will these be ok
CB350/400
Spark plug Caps
