Author Topic: Float Height  (Read 2008 times)
watty51
  • Guest
Float Height
« on: November 18, 2017, 01:57:14 PM »
When measuring the height of the floats what sort of angle would the carb bodys need to be at for the most accurate level.
I have done some research....some say upside down....some say 90 degree....some say 45 degree.
Any ideas
Re: Float Height
« Reply #1 on: November 18, 2017, 02:30:18 PM »
I've always measured them on the side with the float tang just touching the needle of the inlet valve. Make yourself a float gauge to set the correct height. There's plenty of threads on here about 400 carbs and float heights.
