Author Topic: Not charging - Fixed it  (Read 3238 times)
Offline SteveW
« on: November 21, 2017, 03:11:51 PM »
Have replaced the rectifier and regulator as the wiring was burnt out to the rectifier. Have replaced them with the combined solid state unit.
The field coil measures 5 ohms which looks correct and there is battery volts on the white wire to the field coil.
The three yellow wires from the stator measure about 1.0 ohm each which im guessing is correct if you take into account the resistance in the leads of my multimeter. Each of the 3 yellow wires also measure opent circuit to ground.
When the bike idles, im getting around 0.65 volts ac across any 2 yellow wires which is nowhere near enough.
Any ideas? im guessing the stator coil is fried but there is no evidence of any damage to it.
« Last Edit: November 23, 2017, 06:12:20 PM by SteveW »
1980 CB650
2000 CBR929RR Fireblade
1966 Lambretta LI150 Series 3
1981 RD350LC
1972 Raleigh Chopper
1974 Raleigh Tomahawk
2011 Henry Hoover
Offline mike the bike
Re: Not charging
« Reply #1 on: November 21, 2017, 05:45:11 PM »
You won't get any ac generated unless there's 12V across the excitor coil.  That's the one in the middle of the alternator.   The 12V is fed from the regulator.
Offline SteveW
Re: Not charging
« Reply #2 on: November 21, 2017, 06:08:26 PM »
There is 12V on the field coil, I measured the white wire that feeds it, the 12V is good.
The field coil appears good as the resistance of it checks out and its also not shorted to ground.
1980 CB650
1981 RD350LC
2011 Henry Hoover
Re: Not charging
« Reply #3 on: November 21, 2017, 06:15:24 PM »
Is there 12V across the coil.  ie. 0V one side, 12V the other.
12V on one side only tells half the story.   If there's 12V across the coil and if it isn't open circuit,  then it should turn into a magnet,  which should then induce an alternating current in the field coils because of the wriggly iron thing bolted to the crankshaft spinning round.  Getting too technical now.   :)
Offline SteveW
Re: Not charging
« Reply #4 on: November 21, 2017, 06:33:14 PM »
Thanks Mike, i'll double check tomorrow.
1980 CB650
1981 RD350LC
2011 Henry Hoover
Re: Not charging
« Reply #5 on: November 22, 2017, 07:57:26 AM »
Or to put it another way you need 12v on the white wire and the green connected to earth
Offline BigAl (Alan)
    • www.alans-electrics.co.uk
Re: Not charging
« Reply #6 on: November 22, 2017, 05:15:38 PM »
Or splice the white wire and place each end on a AVO meter (as image) if the coil is OK the reading would be around 2 amps (DC amps scale 1-10 amps)
Current bikes:-
Honda CB750 K4 (1974) USA
Honda XL500S (1980) UK
Honda CD175 sloper (1968) UK
Honda CB1100A (2013) UK
Re: Not charging
« Reply #7 on: November 22, 2017, 05:42:52 PM »
I used to have an AVO 8 Mk5 like that.  I prefer my digital clamp meter for current measurements as there's no need to break into the circuit,
Offline SteveW
Re: Not charging - Fixed it
« Reply #8 on: November 23, 2017, 06:15:56 PM »
Just fixed it.
Turns out the green wire from the field coil goes to the middle bottom on the 9 way connector.
But the mating half of the 9 way connector has the corresponding green wire fitted in the middle top.
Moved it back to where it should be and its all working.
Hopefully that is the last electrical bodge on this bike  :o
1980 CB650
1981 RD350LC
2011 Henry Hoover
« Reply #9 on: November 23, 2017, 06:27:42 PM »
Well done.  It's sometimes not easy fault finding other people's bodges.
Offline SteveW
« Reply #10 on: November 23, 2017, 07:29:51 PM »
Just hope the previous owner hasn't touched the brakes  :o
1980 CB650
1981 RD350LC
2011 Henry Hoover
« Reply #11 on: November 24, 2017, 10:42:55 AM »
See 12v across the coil and it works! I have only every seen those coils not work when physically damaged in an accident, seem to be very robust
