Author Topic: Brake fluid Dot 4 ok to use?  (Read 2227 times)
Offline SteveW
« on: November 25, 2017, 04:01:50 PM »
Just stripped down the siezed front brake on the 550, noticed the reservoir cap says Dot 3 only.
Can I use Dot 4?
Not sure I've ever seen Dot 3 for sale.
1980 CB650
2000 CBR929RR Fireblade
1966 Lambretta LI150 Series 3
1981 RD350LC
1972 Raleigh Chopper
1974 Raleigh Tomahawk
2011 Henry Hoover
Offline hairygit
Re: Brake fluid Dot 4 ok to use?
« Reply #1 on: November 25, 2017, 04:43:15 PM »
Yes, and if the whole brake system has been stripped/re sealed you can use DOT 5, which is silicone based, and it doesn't strip paint if you get it on your tank, and is not hygroscopic either, which means it doesn't suck moisture from the air, which means you wont get a rusty caliper piston.  ;D
Offline SteveW
« Reply #2 on: November 25, 2017, 04:53:33 PM »
Thanks very much.
The master cylinder seemed to be okay when i was pumping the seized piston out but I'll probably rebuild that as well due to the age of the seals.
1980 CB650
1981 RD350LC
2011 Henry Hoover
