Author Topic: Is a 4.25 rear tyre too big?  (Read 6226 times)
Offline SteveW
« on: January 25, 2018, 08:37:32 PM »
Just getting my CB550 ready for its MOT, noticed that the previous owner has put a 4.25 wide rear tyre on it.
Seems fit ok, haven't ridden the bike yet due to knackered carbs, electrics etc etc.
Is 4.25 too wide?, I will probably be changing tyres soon, should i go for a 4.0?
1980 CB650
2000 CBR929RR Fireblade
1966 Lambretta LI150 Series 3
1981 RD350LC
1972 Raleigh Chopper
1974 Raleigh Tomahawk
2011 Henry Hoover
Re: Is a 4.25 rear tyre too big?
« Reply #1 on: January 25, 2018, 08:47:54 PM »
Always had 425/85 Tyres on my 500s.
Offline hairygit
« Reply #2 on: January 25, 2018, 08:48:14 PM »
Fitting a 4.25 tyre on the rear was a popular choice back in the day. Don't recall anyone having issues with it, and it raises the gearing very slightly and makes the bike fractionally taller, but it won't be a problem unless you're a shortarse like Mrs Hairy, or a certain member on here with a green 750!
Offline SteveW
« Reply #3 on: January 25, 2018, 08:53:57 PM »
Thanks guys  :)
1980 CB650
1981 RD350LC
2011 Henry Hoover
« Reply #4 on: January 25, 2018, 09:36:59 PM »
I fit a 4.00
That is already 2 sizes bigger than the 3.50 standard for the 500
« Reply #5 on: January 26, 2018, 07:14:29 AM »
4.00 x 18 is English size and 4,25/85 x 18 Metrisish and both sizes are really the same (550 came with 400 x 18)
Offline matthewmosse
« Reply #6 on: January 26, 2018, 08:14:47 AM »
I think the widest tyre I had was a 500/15 that I picked up on a custom rim, that just about fitted cold but rubbed the torque arm sometimes on the move. I suspect going that wide on a stock rim would bunch the tyre up and not be safe....
Offline Moorey
« Reply #7 on: January 26, 2018, 09:52:33 AM »
Where is the Metrisish bit, isn't 4.25 = 4.1/4 inch 85 is tyre wall size as a % of tyre width and 18 the wheel diameter in inches.  So isn't  a 4.25 wider than a 4.00 .  Sometimes another 1/4" can make all the difference or am I wrong.
« Reply #8 on: January 26, 2018, 11:09:14 AM »
The early CB750 I had in the 70's came with an oversize back tyre, 4.25 TT100 I think, coupled with Girling shocks that may have been on the long side (I didn't know any better to find out / go back to standard) it snaked like a pig (if pigs can snake) at high speeds, I got rid after a couple of near terminal experiences, it put me off big Hondas for years.
The K1 I have now has bog stock tyre and shock sizes, and doesn't wobble at all.
« Reply #9 on: January 26, 2018, 11:21:06 AM »
Isn't 4.25  decimal expression of inches, so a sort of hybrid rather than fractions of an inch as would be usual?
So decimal being base ten does make it metrinch-ish by combining the two  :)
It's a real hotchpotch even now with tyres all still having imperial sized rim diameter, plus metric width,  plus % aspect ratio as moorey states.
Offline Seabeowner
« Reply #10 on: January 26, 2018, 04:05:18 PM »
Yes and the rim is 1.85" wide just add to the mix.
Always used 4.25/85 in years of old. The 85% profile coincidentally means the gearing is virtually unchanged,
Standard tyre was 3.50 on 500, 3.75 on 550.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
Offline Tomb
« Reply #11 on: January 26, 2018, 04:14:05 PM »
I use a 120/90 rear on my 500, it works really well - if you want to go totally metric.
Its close but clear of the torque arm though I am using a Dresda box section arm if that makes any difference.
Tom
'62 CB77 Sprinter
'70 CD175
'78 CB550 with sidecar
'80 Z50R
Offline peterengland
« Reply #12 on: January 26, 2018, 05:57:22 PM »
No, it's fine
Suzuki 50
Suzuki GT185
Honda CD175
Yamaha RD350
Honda 50 crunch box
Honda 400/4
Honda 550/4
Honda 750C
Offline Green1
« Reply #13 on: January 26, 2018, 07:12:47 PM »
Just to let you know I have a 400x18 on my 550 and 750 and can reach the floor easily even though I am a wee bit shorter then you freakishly tall people.
Super Moto boots help a little on the 750  ;)
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Triumph tiger 800
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
« Reply #14 on: January 26, 2018, 07:35:08 PM »
Do these “super” boots have high heels then?
