Author Topic: 500/550 Cam cover seals. Pucks.  (Read 3544 times)
Offline Seabeowner
« on: January 26, 2018, 04:00:53 PM »
What's the obvious reason (that I'm obviously missing) that the 500/550s have the 6off sealing washers top of the head/cam cover? The US call them pucks. Why not O rings as there is only a small blind space in the cam cover above and access to head nuts below.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
  • Colonial_clive
Re: 500/550 Cam cover seals. Pucks.
« Reply #1 on: January 26, 2018, 07:36:24 PM »
I missed one out on rebuild and leaked oil everywhere.
« Reply #2 on: January 26, 2018, 08:55:06 PM »
Please try it  ;) I have and it gets a bit messy  ;D ;D
« Reply #3 on: January 27, 2018, 01:05:33 AM »
No groove, only a flat surface so O ring migrates
Offline Seabeowner
« Reply #4 on: January 27, 2018, 11:26:35 AM »
It dawned on me as I woke up this morning. It would need a location in the cam cover or some other form of internal support..and this was the easier option.
The 500 aftermarket gasket sets often seem to come with the pucks, but never found a 550 one with them. Annoying.
« Reply #5 on: January 27, 2018, 11:43:34 AM »
The only difference between 500 and 550 gasket sets is the clutch cover gasket
Offline mickwinf
« Reply #6 on: January 27, 2018, 02:32:18 PM »
surely the head and base gaskets differ?
« Reply #7 on: January 27, 2018, 02:44:51 PM »
Nope mate same part numbers, maybe VERY early 500 head gaskets were a bit smaller hole but when you look at max overbore on 500 to standard 550 there is little difference and the "Fire ring" in the gasket still seals on the liner top
