Author Topic: NEW PROJECT CB750 K1  (Read 91032 times)
Re: NEW PROJECT CB750 K1
« Reply #150 on: October 22, 2018, 09:47:53 PM »
Looking great Paul.....well done.
Thanks Julie  :)
« Reply #151 on: October 22, 2018, 09:49:16 PM »
Coming along very nicely Paul
Cheers James, any spare choke slides ;)
« Reply #152 on: November 13, 2018, 08:24:24 AM »
More new bits arrived carb rubbers and clamps and the rubber dust caps.
Carbs now fully refurbished  ;D ;D
« Last Edit: November 21, 2018, 02:45:12 PM by paul G »
« Reply #153 on: November 13, 2018, 12:03:14 PM »
Paul - really don’t want to ‘piss on your fire’ as you’re doing a super job, but it looks like you’re using the reproduction/non-genuine intake rubbers / clamps from DSS.
Just keep a close eye on them as I have two previous attempts using them, both resulting in chasing air leaks due to poor sealing/manufacturing tolerances. This was after 6 months of light use. Same with the repro fork gaiters, which develop hairline cracks/degraded after 6 months.
I’m not knocking DSS - they do a good job at helping us restore these bikes/keep them on the road, but worth noting where to tread carefully..
Take the above as you will - just wanted to share my thoughts..
« Reply #154 on: November 13, 2018, 01:42:43 PM »
James,
              Not an issue all info greatly received.
They are not repro ones and they wasn't from silvers either James.
I got the originals from a company in Germany you can see the bags for the clamps and dust rubbers in one of the pictures.
I will keep an eye on them all the same as I did have an issue with some for the 400/4 from the said company;) ;)
« Last Edit: November 19, 2018, 08:10:46 AM by paul G »
« Reply #155 on: November 19, 2018, 08:16:42 AM »
Hi all managed to get the carbs on and all the plumbing done. ;D
« Reply #156 on: November 19, 2018, 09:12:09 PM »
Why are the outside carbs more blingy than the inside two  ;D ;D
« Reply #157 on: November 19, 2018, 09:18:45 PM »
I used genuine honda inlet rubbers on my rebuild and i suffered from airleaks. Had to modify the clamps to ensure they put sufficient compression on the rubbers...clamps were gen honda too.. Not an uncommon problem either. Nice looking build by the way  8) good work!
« Reply #158 on: November 19, 2018, 10:04:55 PM »
They aren't Graham just the camera flash ;D ;D
« Reply #159 on: November 19, 2018, 10:06:57 PM »
Cheers Rob
Offline Phil Ward (RIP)
« Reply #160 on: November 19, 2018, 10:07:24 PM »
Looking good Paul
« Reply #161 on: November 19, 2018, 10:13:25 PM »
Cheers Phil.
« Reply #162 on: January 04, 2019, 12:50:26 PM »
Air box fitted ;D
« Reply #163 on: January 04, 2019, 12:51:43 PM »
Some more goodies arrived and should keep me busy at the weekend ;D
« Reply #164 on: January 04, 2019, 12:56:35 PM »
Made a start on refurbishing the switches, if they come out as good as the Z650 ones I will be happy as they were mint 8)
Quite enjoy doing these. :o
