Author Topic: Brake splitter - CB750F2  (Read 4450 times)
Offline Phil Ward (RIP)
« on: February 05, 2018, 05:37:48 PM »
Can anyone confirm if a GL1000 brake splitter will it fit straight onto the 750K bottom yoke? (are the securing bolt hole centres the same as the 750K2 - K6)
And if so does anybody have one for sale - need it for the double disc conversion inc the brake switch. At present I'm using a K one with caliper to splitter pipes banjo in the same hole
Re: Brake splitter - CB750F2
« Reply #1 on: February 06, 2018, 07:40:00 AM »
Dont know if it fits but i got one on a scrap GL1000, take me a week and a gallon of fuel tp get it though
« Reply #2 on: February 06, 2018, 01:33:49 PM »
Thanks Roy - don't go out of your way to get it - I can get one off eBay cheap, just need to know the mounting bolt hole centres if anyone knows
Sent from my Moto G (5) using Tapatalk
« Reply #3 on: February 06, 2018, 02:33:18 PM »
I answer to most things but never had Roy before!
« Reply #4 on: February 06, 2018, 04:36:30 PM »
Sorry Bryan - senior moment! (I get them a lot now). Mixed my 'posts' I was reading up
Offline SamCR750
« Reply #5 on: February 06, 2018, 11:11:31 PM »
Considering most of us are older than our bikes, senior moments seem to come thick and fast, hahaha.
« Reply #6 on: February 07, 2018, 06:34:55 AM »
I resemble that remark!
Offline SamCR750
« Reply #7 on: February 07, 2018, 09:13:20 AM »
hahaha, Sorry Roy or is it Brian.  ::)
Phil, I think I just used a double banjo and it worked fine.
I'm not sure what was used on the original CRs.
Sam. ;)
« Reply #8 on: February 07, 2018, 09:43:18 AM »
Thanks Sam - the original CR had a special - see CR21's (Scott) CR build thread. Scott has made a replica of the original.
Just noticed another senior moment - the title of this thread relates to 'CB750F2' not GL1000! In my defence, I started the thread relating to a CB750F2 splitter and then noticed that the F2 doesn't appear to have a brake pressure switch threaded hole in it (which I want for road use) and then ebay searched and found GL1000 looked the same - and then altered the thread but forgot to change the heading. That's my excuse anyway!
I just thought that the double outlet splitter looked more appropriate to a double disc set up. If the one you built was raced and worked fine with a double banjo set up, my road going version should work fine with that setup.
Have a look at CR21's CR750 build thread - you'll find it interesting - really good build
Offline SamCR750
« Reply #9 on: February 07, 2018, 02:57:30 PM »
Where do I find it Phil, what  section is it in ?
« Reply #10 on: February 07, 2018, 03:15:10 PM »
Try this - its the start of the long thread
http://www.sohc.co.uk/index.php/topic,10090.0.html
« Reply #11 on: February 07, 2018, 06:47:17 PM »
All sorted = its doesn't fit. 750 hole centres 20mm and GL1000 is 40mm.
Thanks for help
