SOHC.co.uk Forums > CB750
Tapping nosie
<< < (8/8)
Nurse Julie:
Is the engine builder the same person / company that reassembled the head?
yozzer74:
Yes it is
Nurse Julie:
So you have your answer then. If your mate asked a company / person to do a job and that job was not done to the standard expected of a competent, professional engine builder, the liability remains with that company but only if your friend can prove that nothing he has done after taking the engine back from the builder, or by supplying his own parts, has contributed to the damage now caused. What I will say is that if it was a well established reputable company, they would have no issues with re doing the work as their reputation is at stake. If it's a tin pot bunch if cowboys who know diddly squat and are playing at being engine builders, good luck, I don't think you will get anywhere.
Trigger:
Did the engine builder ask your mate to supply the parts ? If so, then he was covering his arse.
In a courts the court take a very dim view to any aftermarket parts being used (the same as a main stream manufacture, will not guarantee vehicle if any aftermarket parts fitted or any modifications).
The courts will not back up any claims to any vehicle that is non standard.
Moorey:
If its who and where I think, doesn't he specialise in 750 sohc engine building. Its about 3 or4 years since I was in his workshop.
Navigation
[0] Message Index
[*] Previous page
Go to full version
