Author Topic: Testing carb float levels with water?  (Read 7790 times)
Offline paulbaker1954
« on: May 14, 2018, 04:56:18 PM »
May sound a daft question but am just rebuilding my carbs and wondered if i can test the float level using water (off bike of course !!!)
Just hate messing around with petrol all over the place
But maybe water has some different physical property from petrol that means its not feasible
Also does the level need to be about 2mm below the bowl/body joint from memory?
2016 Yamaha MT09 Tracer
1971 Honda CB500 Four K0
Offline hairygit
Re: Testing carb float levels with water?
« Reply #1 on: May 14, 2018, 05:01:42 PM »
Personally I wouldn't use water, maybe paraffin or meths or even diesel would be better.
Offline kevski
« Reply #2 on: May 14, 2018, 06:51:31 PM »
Better off using petrol as anything else has a different densities and the floats will be at different levels, just be sensible and you will be fine.
« Reply #3 on: May 14, 2018, 07:07:11 PM »
That’s what I thought given my aged memory of physics and eureka
Offline deltarider
« Reply #4 on: May 14, 2018, 07:58:51 PM »
Rule of thumb: the floatlevels are NEVER wrong unless floats have been messed with. I sure hope this American epidemic doesn't spread here.
« Reply #5 on: May 14, 2018, 09:16:50 PM »
Cant you just use a guage or a rule like it says in the manual?
Offline kevski
« Reply #6 on: May 14, 2018, 10:13:29 PM »
As bike is 40+ years old, Rule of thumb is check the float levels, as you never know what previous idiots, err i mean owners have done.
Offline deltarider
« Reply #7 on: May 15, 2018, 07:09:16 AM »
Unfortunately too many mistake another problem for an incorrect floatheight. Incorrect fuelline length and diameter (kinking), good-for-nothing 'extra' inline fuelfilters that intermittently hinder fuelflow and sticking valveneedles. It takes very little indeed, to disturb the gravity feed of just a few centimeters difference in height. I would start with having the correct fuellines and - especially after hibernation - eliminating sticking valve needles. An additive may help. I myself have never encountered a CB500/550 float that needed to have it's tang adjusted.
The correct dimensions for CB500 fuellines is 18 and 30 cm (old style petcock) or 17 and 28 cm for models that had the newer type petcock. ⌀ 5,5 mm.
Offline kevski
« Reply #8 on: May 15, 2018, 07:15:02 AM »
You are missing the point, Check does not mean adjust and previous owners, to blythly refurb which original poster is doing without checking everything would be foolhardy.
« Last Edit: May 15, 2018, 07:16:41 AM by kevski »
« Reply #9 on: May 15, 2018, 12:56:19 PM »
Concur whats the point of stripping the carbs, ultrasonic clean, new jets and O rings and NOT checking float levels !!!!
BAck to my original question should the level be about 2 mm below the bowl/body join line. I am sure I have seen a number of posts on this but cant seem to locate obe
Offline Seabeowner
« Reply #10 on: May 15, 2018, 03:09:35 PM »
The manual only shows a measurement with the bowl removed, with the carbs on their side with the float tang just touching the needle. It should be 22mm from the flange to (what is) the bottom of the float.
But 2mm below the flange for the (so called) clear tube test is what I use.
The tang is pretty stiff and will not change unless interfered with, but aftermarket needles may alter level.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
Offline kevski
« Reply #11 on: May 15, 2018, 03:53:27 PM »
Agree with this, i have after market needles in my 350/4, i had to adjust the tangs on the floats as the needles were shorter and would not shut off the fuel supply.
« Reply #12 on: May 15, 2018, 05:04:51 PM »
I found that testing with water doesn't work!
I had a fuel drip from the float bowl overflow pipe on my 400/4. It had new float valves but I checked the one that was dripping for dirt and made sure it was seating ok. Still dripping.  :(
I'd read that the brass overflow pipes sometimes crack and cause a leak so I took off the float bowl again and filled it with water. No leaks, so it must be ok, right? Wrong.
When I checked the bowl again with fuel it didn't leak at first, but after a minute or so it started dripping very slowly and the outside surface of the external pipe was wet. It must be finding a way down the side of the pipe between the aluminium bowl and the pipe.
I won't check with water again.  >:(
Offline matthewmosse
« Reply #13 on: May 15, 2018, 05:52:37 PM »
Water might well not find it's way through a gap petrol will creep through. I wouldn't  be using it as it's asking for a tiny bit to stay behind and cause alloy to corrode and block something or dry out and leave a deposit of stuff to block jets. Carbs are a pain to start with so deffinately worth checking so as to avoid future doubt and stripping and reassembly. But I would do all checks with fuel, it may smell bad etc but it's what you are trying to get it working with so you eliminate variables and Don't introduce things that are not meant to be there and bring their own issues.
« Reply #14 on: May 16, 2018, 06:45:11 AM »
Well known issue is hairline cracks in the overflow pipe. I once spent ages trying to chase down what I thought was a float valve not seating only to eventually spot this hairline crack
I tried fixing it with jd weld but eventually petrol ate its way past it and gave up and sourced a new float bowl but they are getting harder to find at sensible prices
