Author Topic: Speedo Drive  (Read 7061 times)
Offline Deano400
Speedo Drive
« on: May 16, 2018, 12:22:58 PM »
I'm looking for some advice on my speedo drive. I would like to strip and clean up. Has anyone got any tips on getting it apart? Little screw comes out easily enough but where do I go from there without butchering it?
By little screw I don't mean the one in the picture, it's a very small one out of view.
Offline hairygit
Re: Speedo Drive
« Reply #1 on: May 16, 2018, 12:49:05 PM »
On the opposite side to what the picture shows you will find a circlip holding the large gearwheel in place, remove that and the gear wheel, and that in turn should release the spindle that drives the cable (after removing the screw you refer to) Wash all parts in something to remove all the old manky grease, dry thoroughly and check everything for wear or damage. If all okay, apply fresh grease and re assemble.
Offline Deano400
Re: Speedo Drive
« Reply #2 on: May 16, 2018, 12:59:52 PM »
Thanks Hairy much appreciated.
Offline Deano400
Re: Speedo Drive
« Reply #3 on: May 16, 2018, 01:55:00 PM »
Yes can see the circlip now I've removed a load of crud.
Offline Deano400
Re: Speedo Drive
« Reply #4 on: May 16, 2018, 09:12:57 PM »
Circlip is out, gear wheel is out, little screw is out, but I can't get the spindle / plug out, any ideas?
Offline Deano400
Re: Speedo Drive
« Reply #5 on: May 17, 2018, 03:31:34 PM »
Spindle and plug out today.  :)
Put the speedo drive in the freezer for a couple of hours then applied a bit of heat to the casing then tapped out the spindle with my newly acquired spindle removal tool!! Came out quite easy, only a few light taps.
Offline GregShiv
Re: Speedo Drive
« Reply #6 on: May 17, 2018, 08:39:03 PM »
Does anyone know a part number for the seal that goes onto the speedo gearbox?
1983 Suzuki GSX550ESD
2013 Aprilia SL750 Shiver
1976 Honda CB400F
Offline Deano400
Re: Speedo Drive
« Reply #7 on: May 17, 2018, 09:04:52 PM »
Do you mean this seal? AE1967E
The parts book only shows the complete unit and not the seal as a separate item.
« Last Edit: May 17, 2018, 09:13:56 PM by Deano400 »
Offline GregShiv
Re: Speedo Drive
« Reply #8 on: May 17, 2018, 09:34:38 PM »
Yes that is the seal.
I want to strip and clean my speedo drive but if the seal gets damaged when removing it I would like to be able to source a replacement.
I have tried to remove the seal but it seems to be stuck fast so might get damaged.
1976 Honda CB400F
Offline GregShiv
Re: Speedo Drive
« Reply #9 on: May 17, 2018, 09:45:03 PM »
I found this thread while Googling AE1967E
http://forums.sohc4.net/index.php?topic=171490.0
1976 Honda CB400F
Offline Deano400
Re: Speedo Drive
« Reply #10 on: May 17, 2018, 10:00:02 PM »
Re: Speedo Drive
« Reply #11 on: May 17, 2018, 10:12:48 PM »
Recently discussed on here
May help you out.
Offline GregShiv
Re: Speedo Drive
« Reply #12 on: May 17, 2018, 10:20:58 PM »
Deano400,
That eBay link is BearingshopUK I Googled them and they are in Rochester in Kent, I happen to have a job there tomorrow I will pop in and see if they have one available.
K2-K6,
I was born in Wimbledon and now live in Sutton so not far from you.
1976 Honda CB400F
Offline Deano400
Re: Speedo Drive
« Reply #13 on: May 17, 2018, 10:23:22 PM »
Coincidence or what!!! Let me know how you get on.
Re: Speedo Drive
« Reply #14 on: May 17, 2018, 11:17:43 PM »
Gregshiv,  I've moved in to London some time ago nearest to what is known here now as West Wimbledon and used to be Raynes Park.
Did you use the Aprillia dealer that was once over this way? It was at the end of my road.
Hope you get the seals sorted on your trip to Rochester.
