Author Topic: Can you strip the kill switch down?  (Read 3931 times)
Offline SteveW
« on: June 03, 2018, 08:36:56 PM »
Got a very slightly intermittent kill switch on the 550, when the bike is running its fine.
If you turn the bike off with the kill switch, put it back to on, the bike will sometimes not fire.
Moving the switch a few times through the positions and then back to on, it fires up.
Think it just needs a clean, but wasn't sure if it can be stripped down?
1980 CB650
2000 CBR929RR Fireblade
1966 Lambretta LI150 Series 3
1981 RD350LC
1972 Raleigh Chopper
1974 Raleigh Tomahawk
2011 Henry Hoover
Re: Can you strip the kill switch down?
« Reply #1 on: June 03, 2018, 08:58:46 PM »
The switch can be fully stripped  ;) I have done loads of them .
Offline mike the bike
« Reply #2 on: June 03, 2018, 09:05:38 PM »
There's a very small E clip holding the plastic knob on to  the top half of the switch.   It's best to disassemble it on the table to avoid parts disappearing.
Offline SteveW
« Reply #3 on: June 03, 2018, 09:57:23 PM »
Thanks guys
1980 CB650
1981 RD350LC
2011 Henry Hoover
Offline Seabeowner
« Reply #4 on: June 04, 2018, 08:59:11 AM »
Is the movement of the switch positive. Have you tried switch cleaner, some may get to the contacts. I had an earlier 500/750 type that was intermittent and dismantled it. But some gorilla had turned the switch too far and the metal contact and the location of the detent ball were pretty mashed. Managed to make it a bit better but not perfect. It was the P L H type and sold it. Make sure you have a very good fitting screwdriver for the little screws on the wiring guides etc. and take it easy, they can shear.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
« Reply #5 on: June 04, 2018, 10:29:44 AM »
The e-clip is easy to remove but a bit of a pain to replace with pliers, if you have three hands it helps! You can buy specific e-clip pliers on ebay. Take lots of photos before you strip the switch, there are a lot of very small parts and the internal wiring routes can be easily forgotten.
Offline SteveW
« Reply #6 on: June 04, 2018, 08:19:59 PM »
The switch feels perfect when you operate it.
I might try some contact cleaner in it first before I resort to stripping it down.
1980 CB650
1981 RD350LC
2011 Henry Hoover
« Reply #7 on: June 04, 2018, 11:14:50 PM »
Be careful,  aggressive switch cleaner can break 40 year old plastic.  Best strip it down and do the job properly, polishing and greasing the contacts and checking the soldered connections.  As mentioned,  take photos.
