Author Topic: electrical problems !!!  (Read 3865 times)
« on: June 26, 2018, 08:02:12 PM »
  have asked,and received a replacement speedo bulb holder,thought it would be about an hurs job to fit,
 was it hell !!  I seem to have issues ,
 when I turn on the lights,only the side light comes on,put it in park,the speedo and tacho ,with the rear light comes on,
 indicators work perfectly,headlamp flasher works ,
I think a wire must have been switched !!,but I only have wiring diagram for USA model,no seperate light switch ,and no pilot bulb.
CAN ANYONE GIVE ME A LINK TO A 500/4 K1 UK model wiring diagram?
 need to get sorted for sunday !!
Re: electrical problems !!!
« Reply #1 on: June 26, 2018, 08:58:27 PM »
John. We have a UK k1 wiring diagram here, I will email you over a copy.
« Reply #2 on: June 26, 2018, 09:03:32 PM »
What colour wires are coming from the speedo/tacho bulb holders.
  green for earth ,and brown/white for power,
 I need to know what pilot cable is ,also the power lead to the switch gear on RH handle bar ,maybe they got switched
« Reply #3 on: June 26, 2018, 09:04:13 PM »
  thanks Julie XXXX
Offline Underdog1
« Reply #4 on: June 26, 2018, 10:09:10 PM »
Here’s all the SOHC four wiring diagrams
http://manuals.sohc4.net/cb500/
EDIT: sorry mate seems it’s US bike only on there!
« Last Edit: June 26, 2018, 10:10:54 PM by Underdog1 »
Offline Woodside
« Reply #5 on: June 26, 2018, 10:19:57 PM »
uk k1
« Reply #6 on: June 26, 2018, 11:15:15 PM »
uk k1
  thanks for all your help,
  I shall be grafting on it in the morning
« Reply #7 on: June 27, 2018, 11:46:51 AM »
uk k1
  job done ,I had accidently swopped a brown and blue wire with a brown wire .
 will be going to Northleach this evening ,so that will check it out .
 thanks to everyone that helped and supplied a UK wiring diagram,
the Haynes manual uses a US  ne without side light,but it shows a UK headlamp  in photos
