Author Topic: 18.5 x 34 washer thickness  (Read 4678 times)
Offline sye
« on: July 29, 2018, 03:56:46 PM »
I'm getting together the bits that are missing for the eventual rebuild. Someone has put a brass shim under the swingarm rear axle nut instead of the 18.5 x 34mm washer, which is unavailable as a genuine part. M18 x 34 x 3mm thick washers are readily available and will do the job but does anyone know the original washer thickness please?
Thanks, Sye.
« Last Edit: July 29, 2018, 04:57:33 PM by sye »
Offline Seabeowner
Re: 18.5 x 34 washer thickness
« Reply #1 on: July 29, 2018, 05:08:33 PM »
Just took one off my 550. It's 4mm. My 500K0 is the same but, didn't want to disturb it. My other 500 has a non standard washer that looks about 1mm, so would be interested in getting at least a 3mm for that.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
« Reply #2 on: July 29, 2018, 05:19:07 PM »
As long as you do the nut up tight the actual thickness is not mechanically relevant
« Reply #3 on: July 29, 2018, 06:48:22 PM »
Not sure about 18.5 x 34mm washer ! The OEM size is ID 14.30mm, OD 25.90 and 2mm thick  ;)
Be careful of honda sizes listed  :o
The washer for the swing arm is available 90526 268 000
OK, just seen the swingarm bit crossed out.
That was original a chrome washer. Can post you a S/S one if you require Sye
« Last Edit: July 29, 2018, 07:03:03 PM by Trigger »
Offline sye
« Reply #4 on: July 29, 2018, 08:43:18 PM »
Thanks for your offer Graham but I have form A stainless M18 washers at 3mm thick with a 34mm o/d in my spares box. I will polish it up so it looks chrome and it should look fine.
Offline Seabeowner
« Reply #5 on: July 30, 2018, 08:47:31 AM »
I know but my 1mm looks a bit weedy.
I would be interested in a better replacement for that if one is available please.
« Reply #6 on: July 30, 2018, 11:29:06 AM »
The OEM chrome washer was 4mm thick, the S/S ones i have are only 2.60mm. If you want one PM me your address and i will pop one in the post  ;)
Offline Seabeowner
« Reply #7 on: July 30, 2018, 06:27:50 PM »
Cheers Trigger. It will look better than the one I have now. I have the 4mm on the other two. I'll stick an extra quid on the donations next round.
