Author Topic: CB750F2 .... silk purse from a sows ear.  (Read 174259 times)
Re: CB750F2 .... silk purse from a sows ear.
« Reply #45 on: August 02, 2018, 01:44:15 PM »
Here's a diagram of the breather system.
« Reply #46 on: August 02, 2018, 01:54:43 PM »
Found more
« Reply #47 on: August 02, 2018, 02:13:09 PM »
Just for inspiration, I also found out that my knees and other bodily parts do not work as they used to so when lumping around the engine on mine I had to ask the grandson for help and be creative. So with a nicely finished engine and frame I gave him the call and we fitted the frame to the engine, using some blocks of wood, bricks and some carpet.
Offline SumpMagnet
« Reply #48 on: August 02, 2018, 04:08:48 PM »
I already got the oil filter housing loosened...was worried the bolt might be siezed....but it shifted no bother.
CB750F2 - in pieces
Offline SumpMagnet
« Reply #49 on: August 03, 2018, 08:03:16 AM »
Spitfire..that is brilliant info. Many thanks.
And I hope my motor looks as tidy when I put it back in!
CB750F2 - in pieces
Offline SumpMagnet
« Reply #50 on: August 03, 2018, 02:04:29 PM »
Bugger...
Minor slip lifting the frame, after I forgot the breather cover.. and stopped to remove it. Damn thing settled and nipped my hand between head and frame. Inch long gouge in hand and claret all over the shop. Joy.
Off to casualty and a few days delay finishing the job.
Damn...damn....damn and bother.
Still..on the plus side, all the engine bolts came out sweet and there are no cracks, chunks or nasties on the cases I can see. There are some dog eared screws on the end cases, and I know they are not coming out without a fight. The X is already an O..
Had an oil leak from under the generator cover, so that will need looking at. Not sure there should evenbe oil there....
So.
1) get stitched up
2) clean up the message I made
3) work out how to do this job with one less hand....
CB750F2 - in pieces
Offline hairygit
« Reply #51 on: August 03, 2018, 02:38:10 PM »
The CB750 alternator runs in oil, so there should be oil in there.
Offline SumpMagnet
« Reply #52 on: August 03, 2018, 05:23:05 PM »
Ok...that's a relief :)
I think someone tried to get in there before, butchered the screws trying to get the end cover off...then just took the whole thing off and refitted with the old gasket. It looked all fine diwn there, but was leaking badly. Once i get around to it....I will clean all the muck away and have a proper look and check for signs of damage.
Meantime...doctors orders say no lifting/heavy work for at least a week...then it's back to getting the frame off then engine. Breaks my heart seeing her lying on her side out the back...and me unable to help. Still...the motor is supported on wooden blocks and I have wedged the frame too, so the end cases are nowhere near the deck, and the load is on the block/barrel and engine mounts.
CB750F2 - in pieces
Offline Moorey
« Reply #53 on: August 03, 2018, 07:42:41 PM »
Man that Vessel JIS T driver takes me back  .. our local 5-star Honda dealer sold me mine in 1971 (Peters of Hull) Excellent bit of kit.
I wish you could still get them. I could do with some new ones.
« Reply #54 on: August 03, 2018, 07:54:08 PM »
Wow that engine looks beautiful! Great paint job!
Offline Green1
« Reply #55 on: August 03, 2018, 08:12:34 PM »
I have one its been bent and the plastic hand grip is missing but its still the go too screwdriver because it works.
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Triumph tiger 800
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
« Reply #56 on: August 04, 2018, 10:03:16 AM »
You can get them as a Honda part number but sit down before you order!
Offline Phil Ward (RIP)
« Reply #57 on: August 04, 2018, 01:49:37 PM »
Found more
Sorry to high jack the thread but been following the thread and in the diagramme I noticed the 'breather separator' and this may be an answer to my need for a oil tank catch tank if I modify it (I'm struggling for space under the hump where the tank normally goes as I have put a battery there).
Can anybody give me some dimensions for this part please - part number 17360405000
Thanks guys
« Reply #58 on: August 04, 2018, 02:06:59 PM »
I am not sure why you need a catch tank ? If the breather pipe comes off the breather cover, them just do a pipe like on the K6  ;)
« Reply #59 on: August 04, 2018, 04:37:29 PM »
There's an overflow that goes back to they rear crankcase but 2 more rear facing overflow pipes that exit right over the rear wheel - don't fancy just pipes!
Sent from my Moto G (5) using Tapatalk
