Author Topic: Big thanks to Peter (Kent400)  (Read 5807 times)
Offline sye
« on: September 08, 2018, 05:34:12 PM »
Had my gauges done by Peter and had to post this as a recommendation of his outstanding work. To say I'm delighted is an understatement, they look like new. The picture below doesn't do them justice.
Re: Big thanks to Peter (Kent400)
« Reply #1 on: September 08, 2018, 06:12:10 PM »
That's my job for this winter :)
Offline GiannisFour
« Reply #2 on: September 08, 2018, 06:37:05 PM »
Brilliant work!
mines soon on the way to Peter  :)
CB500 K1
CB400 F2
Offline andut
  • CB400F, CB400F Cafe & NC30
« Reply #3 on: September 08, 2018, 07:57:54 PM »
+1 on Peter's gauge restoration service - wouldn't hesitate to recommend him.
« Reply #4 on: September 08, 2018, 08:07:04 PM »
+ another 1,  excellent work every time.
Offline Phil Ward (RIP)
« Reply #5 on: September 08, 2018, 11:03:48 PM »
Steve, what clocks are you having done - thought you have sold the 500?
« Reply #6 on: September 09, 2018, 10:13:36 AM »
What clocks are you having done - thought you have sold the 500?
Did you miss my post (and name change?)
James got me this:
« Reply #7 on: September 09, 2018, 10:42:41 AM »
I did miss that Steve, so you sold your old 500 and bought another from James? Did you miss the 500!
Didn't get the change of name bit. (to what?)
Lots of questions there!
PS - almost contacted you to buy the 500 but someone beat me to it - to the relief of my wife!
« Reply #8 on: September 09, 2018, 12:34:28 PM »
The bike I sold was a UK K1 from 72. It went to a member on here who will probably own up one day.
The new bike is a very early K0 (April 71) from the States. It was refurbed to James’ normal high standard (note - not restored). The clocks show 6000 miles and are well faded. The tacho oscillates wildly between zero and the red line .
The plan is to ride it until the weather breaks and then to send the clocks to Peter.
Offline Seabeowner
« Reply #9 on: September 09, 2018, 01:53:14 PM »
And also excellent, freely given advice.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
« Reply #10 on: September 09, 2018, 01:55:41 PM »
I have spare parts for the 500K0 tacho Steve ..so if Peter finds he needs them,  just shout. On my original March 71 500K0  tacho the screws had vibrated oval holes in the faceplate ...I gather it's a common problem.
Offline kent400
« Reply #11 on: September 09, 2018, 02:56:55 PM »
Thanks Sye, they were quite a decent pair to start with! Faces (aluminium) were supplied by Marcel our forum sponsor.
I do have a decent 500 four tacho face that could go again. As Ash mentioned the face screws do be come loose leading to the holes becoming oval. Thread lock was used on the screws upon original assembly but strangely one some gauges the screws are tighter than others. Later gauges have plastic faces and they don't seem to come loose. Those plastic faces are secured with screws with a larger head.
A wavering needle can often be traced to a drive cable in poor condition, they can bind as the rotate and that results the cable slowing down , and speeding up. As a consequence the needle wavers.
