Author Topic: Drain tube  (Read 9100 times)
Re: Drain tube
« Reply #15 on: September 13, 2018, 07:10:41 PM »
The peice of gauze in the panching plate, I think that's how you spell it, filters the oil from the engine blow by gases and recycles them through the carbs. I use the foam part of a kitchen sponge, always have done.
So do I, cos Julie told me to! :o
Good Boy Peter, you know it makes sense  ;D ;D ;D
Re: Drain tube
« Reply #16 on: September 13, 2018, 09:20:53 PM »
Just a small issue that might confuse people.
I call the black plastic box connected to the back of the carbs as the air box.
Where the air filter lives is the air filter case or box.
Some people seem to be calling the air filter case the air box. Am I right or are they?
Confused 😕
Re: Drain tube
« Reply #17 on: September 13, 2018, 09:35:02 PM »
I call the black plastic box connected to the carbs the air chamber and the box which contains the filter, the air filter box.
Offline Athame57
Re: Drain tube
« Reply #18 on: September 13, 2018, 10:57:22 PM »
Guilty as charged!
I brake for animals!
1978 CB400F2 named Elen.
