Author Topic: 750 F2 engine bars..  (Read 1699 times)
Offline Wil
« on: September 26, 2018, 06:19:12 PM »
Hi..I recently picked up some engine bars for my cb750/F2...but on trying to fit them I realized the 2 engine mounting bolts will be to short in length !!! ..is my easiest solution to just buy some longer threaded bar ? As I don't think bolts etc will work because of channel that mounting rod runs through?.. Any thoughts welcome...regards Wil.
Offline hairygit
Re: 750 F2 engine bars..
« Reply #1 on: September 26, 2018, 07:14:54 PM »
Probably, or take an angle grinder and thin the mounting blocks down on the frame( DON'T DO THAT!, only kidding!)
Offline Wil
« Reply #2 on: September 26, 2018, 07:57:26 PM »
Lol...👍
« Reply #3 on: September 26, 2018, 08:20:05 PM »
I would not use threaded bar . After some years the road grit collects in the threaded part and is a nightmare to get the bars back out, if need be.
Any good engineering firm will make you a longer set of mounting bars and bolts  ;)
« Reply #4 on: September 27, 2018, 01:14:28 AM »
New ones came with longer bolts and nuts to fit as the thread was different
