Author Topic: Gasket set where from?  (Read 3395 times)
Offline SteveW
« on: September 29, 2018, 07:00:01 PM »
My head gasket is weeping oil and getting worse although the bike still pulls like a train.
Where is the best place to get from, any makes to avoid?
Could i get away with just changing head gasket or will removing the head disturb the base gasket?
Thanks.
1980 CB650
2000 CBR929RR Fireblade
1966 Lambretta LI150 Series 3
1981 RD350LC
1972 Raleigh Chopper
1974 Raleigh Tomahawk
2011 Henry Hoover
Re: Gasket set where from?
« Reply #1 on: September 29, 2018, 10:08:08 PM »
Cylinder comes off in frame and base gasket is in top end kit so i always rekon might as well change that and base o rings. Are you sure the leak is head gasket as it is relatively common to get an oil leak from under the steel bracket at the end(s) of cam cover where a soft sealing washer should be between bracket and cover.
I did have some decent gasket sets i imported from the US if you wish i will see if i have any left
Offline heliwilly
« Reply #2 on: September 30, 2018, 09:37:20 AM »
Ref SteveW's post about gaskets.
I am starting my first 550 strip down and am going to need a full gasket set. Are there any recommendations of the best place to buy them?
Thanks Bill W.
« Last Edit: September 30, 2018, 07:27:25 PM by heliwilly »
« Reply #3 on: September 30, 2018, 10:17:10 AM »
Bill the only difference between the 500 and 550 sets is the clutch cover gasket
« Reply #4 on: September 30, 2018, 12:16:23 PM »
Are the head and base gaskets not different as well Bryan due to the different bore sizes?
« Reply #5 on: September 30, 2018, 12:48:41 PM »
As Bryan said, all the same apart from the clutch  ;)
Offline SteveW
« Reply #6 on: September 30, 2018, 03:50:07 PM »
Been out for a ride today, done 75 miles.
Here are a couple of pics of the leak, does this look like head gasket starting to go?
1980 CB650
1981 RD350LC
2011 Henry Hoover
Offline Seabeowner
« Reply #7 on: September 30, 2018, 06:29:14 PM »
I am just rebuilding the top end of a 550F and only have a 500 gasket set and was thinking that. Thought I would have to mod. Thanks for that!
Infuriatingly every 550 top end gasket set I have bought has not included the 6 "pucks", every 500 one has. They are expensive to buy singly.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
