Author Topic: Tacho cable  (Read 2571 times)
Offline Chris whit
Tacho cable
« on: October 01, 2018, 11:45:26 AM »
Hi All , wonder if anyone knows the correct length for the tacho cable on a 400 four . I have tried to root it correctly as per the assembly manual but it seems too short and will only allow me to root behind the bottom fork yoke and not in front as per manual , think the pervious owner might have fitted a non standard cable .
thanks for any help .
Re: Tacho cable
« Reply #1 on: October 01, 2018, 12:09:50 PM »
The closest I can measure it to on the bike is 570mm from end of fitment to end of fitment Chris.
Re: Tacho cable
« Reply #2 on: October 01, 2018, 12:14:02 PM »
But, it goes behind the bottom yoke, not in front.
Edit...i think, I will have another look in a minute 😀😀😀
« Last Edit: October 01, 2018, 12:16:31 PM by Nurse Julie »
Re: Tacho cable
« Reply #3 on: October 01, 2018, 12:23:57 PM »
This is how mine is routed
Offline Chris whit
Re: Tacho cable
« Reply #4 on: October 01, 2018, 12:35:59 PM »
Thanks Julie , ill check the length later , I've had a look at the diagram and it looks like the cable goes in front and below the  bottom yoke , not the clearest view .
