Author Topic: Fork lowers original finish?  (Read 10879 times)
Offline Sprocket
Re: Fork lowers original finish?
« Reply #15 on: November 19, 2018, 08:38:11 AM »
Julie, the gap in the fork clamp is supposed to be at the back not the front
So, interesting find number #3856433/23b. The fork end clamp pieces are asymmetrical. There's about a 2mm difference between the shoulders. If the gap is supposed to be on the rearmost stud, does it follow that the shorter shoulder should also be on the rearmost stud?
« Reply #16 on: November 19, 2018, 09:46:30 AM »
Fairly sure there is an arrow embossed in the bottom of them which points forward if installed correctly.
No arrows on mine Ken but Graham says some do, some don't.
Offline Sprocket
« Reply #17 on: November 19, 2018, 09:52:30 AM »
So, any idea which shoulder faces the wind then?
« Reply #18 on: November 19, 2018, 11:34:52 AM »
The clamps have an arrow on them that faces forward and the front stud is done up first
« Reply #19 on: November 19, 2018, 12:39:56 PM »
The high shoulder is at the front
« Reply #20 on: November 19, 2018, 02:55:35 PM »
I'm stripping my CB750 K2 and these don't have an arrow either but they do have an F, you can just see it on the top right. [ Guests cannot view attachments ]
Offline Sprocket
« Reply #21 on: November 19, 2018, 03:26:35 PM »
Excellent, thanks guys! :)
« Reply #22 on: November 19, 2018, 04:37:30 PM »
Yes gap at the back, think of it as so the rain doesn't get in. I'm sure that isn't why it's like that, but it helps me get my head around it and get it right.
For something as safety critical as holding the front axle in the right place you'd think Honda would have made it bleeding obvious or impossible to do wrong rather than just assume everyone had seen and memorised the service bulletin / manual.
My CL450 barn find fork legs took 2 or 3 hours each to make shiny, one was crusty, one was like NOS but covered in yellowed laquer. I used P800 wet, followed by the polishing wheel.
« Reply #23 on: November 20, 2018, 11:01:57 AM »
I'm stripping my CB750 K2 and these don't have an arrow either but they do have an F, you can just see it on the top right. (Attachment Link)
I can actually see an arrow on that Julie, it's just above the J marking and is pointing forward. I may have been wrong about the arrow or maybe it;s just the 500 that got those but they all have some sort of marking like the F for forward to show orientation.
I know you are just winding me up Ken 😀😀😀 Here is a better pic, I defo can't see an arrow, a J, a D and an F but no arrow.
Offline Clem2112
  • Midlife
« Reply #24 on: November 20, 2018, 07:19:56 PM »
If in doubt there's always the owner's manual...
Offline Clem2112
  • Midlife
« Reply #25 on: November 20, 2018, 07:20:46 PM »
So long as you can read it upside down
Offline Clem2112
  • Midlife
« Reply #26 on: November 20, 2018, 07:55:29 PM »
Don't bither with powder coat especially on alloy castings.
Out-gassing apparently !
These British ones will now be getting flatted back to be wet sprayed silver and clear coated like car wheels.
