Project Board
1976 CB550F1 (what have I let myself in for) Project
7
8
9
10
27
Topic: 1976 CB550F1 (what have I let myself in for) Project (Read 153313 times)
eight0
SOHC Expert
Re: 1976 CB550F1 (what have I let myself in for) Project
Reply #105 on:
January 07, 2021, 09:35:27 AM »
Ok thanks again for the advice oddjob. If the ones next to the rotor are brown (1 and 2), strange you cant see the colour on them but that bearings 3-5 do look brown!
Bearings are coming out at £142 on CMSNL. Any other cheaper sources you know of before I take the plunge? DSS only has greens and are a similar price anyway.
Thanks for the advice and putting up with all the Crankshaft pics!
Do the rod bearings look ok?
Last Edit: January 07, 2021, 11:59:39 AM by eight0
eight0
SOHC Expert
Reply #106 on:
January 07, 2021, 04:34:36 PM »
Oh man, ok. All rods are E2.
eight0
SOHC Expert
Reply #107 on:
January 07, 2021, 08:37:16 PM »
Actually the colour is clearly visible on the rod bearings. All brown. Do you think I should order 8 then or just 4?
eight0
SOHC Expert
Reply #108 on:
January 08, 2021, 09:00:43 AM »
Hey, some people like to collect penny blacks, others, black bearing shells.
OK, I've ordered 8 brown rod bearings, 4 brown and 6 green crank bearings. I imagine they will take some time to arrive..
Thanks for all the advice oddjob.
Last Edit: January 08, 2021, 09:03:18 AM by eight0
eight0
SOHC Expert
Reply #109 on:
February 09, 2021, 05:57:23 PM »
So I've finally got the bearings I ordered.
Actually I got double the order as cms took weeks and it didn't look like it was going to happen so I cancelled the order and ordered for more money from DS. Both ordered turned up within a day of eachother! Ah well, I can send one back.
Unbelievably, having now taken the old bearings out of the cases, they are clearly ALL browns. The case markings are BBAAA so if as oddjob says, the A's must be either green or yellow, someone must have had this engine open before and installed all browns.
What should I do! If I open both orders from CMS and DS to check tolerances with both green/brown and all brown I can't return the bearings.
Does make me wonder whether the rods which had all browns were right either.
eight0
SOHC Expert
Reply #110 on:
February 09, 2021, 07:13:13 PM »
Well, I have just put the old bearings in and 2 of the new brown bearings on 5 and 6 where the greens are supposed to be.
Not great.
Also I have just noticed this.
Feeling a little deflated.
Reply #111 on:
February 09, 2021, 08:23:07 PM »
The main i would live with but the big end is junk
eight0
SOHC Expert
Reply #112 on:
February 09, 2021, 08:24:55 PM »
What are my options
Johnny4428
Reply #113 on:
February 09, 2021, 09:10:03 PM »
Feel your pain eight0, is that also pitting where the crankshaft seal sits? Wish I could give you something positive.
Reply #114 on:
February 10, 2021, 12:28:31 AM »
Only option is different crank. 500 and 550 are the same so should be a few out there, dont think i got a spare as too many projects
eight0
SOHC Expert
Reply #115 on:
February 10, 2021, 09:50:48 AM »
well, the condition of the engine lives up to the threads title I guess.
I've ordered another crank from DK which also has the rods with it. You never know, the bearings on those rods might be re-usable.
Without sending the cases and crank to a machine shop to get measures for clearance, my plan is to put all the old brown bearings in to see how off they are using plasitguage and go from there.
Trigger
Engines built on reputation, not advertising.
Reply #116 on:
February 10, 2021, 01:17:47 PM »
You can not go by crank markings. The Honda Manuel is reference to new parts only and not to something that has done 50,000 to 80,000 miles with wear and tear
eight0
SOHC Expert
Reply #117 on:
February 11, 2021, 02:59:08 PM »
The 'new' crank arrived. Much easier to see the markings.
From left to right. 21112
My case is BBAAA so with the new crank it should be brown, green, yellow, yellow, green.
I put the crank in with all the old brown bearings and the plasitgauge measured .51 .51 .51 .38 .51
I put a new brown bearing on just to see if there is much difference.
Maybe I'm best off just installing browns all round. What do you think?
eight0
SOHC Expert
Reply #118 on:
February 11, 2021, 05:37:34 PM »
Thanks Ken, that might work if you have that many yellows!
No, not corrosion, just some dirt. I hadn't cleaned it yet when I took those pics.
Yeah rod bearings all need replacing.
They are all marked 1 on the rod and BAAA on the crank so I make that green, and 3x yellow.
I bought all browns!
Reply #119 on:
February 12, 2021, 12:58:00 PM »
Thats cos people like me just fitted black shells and ran the in carefull Ken
7
8
9
10
27
Project Board
