Author Topic: Our girls in the undress?  (Read 20924 times)
Offline Golfcarmad
Re: Our girls in the undress?
« Reply #30 on: January 03, 2019, 08:04:22 PM »
Thanks.i think mine is wrong.i will try to upload photo for comments and advice.i don’t want to split cases unless 100% necessary.i have had trouble uploading photos before.so bear with me and thank you and happy new year
More bikes than sense!!
Honda 400/4 (almost fully rebuilt)
Triumph TR25W
Yamaha Virago 1100
Suzuki GSX750ES
Yamaha Virago 535
Honda CBR500F (Import)
Francis Barnett Plover
Puch Maxi 2 speed (makes me smile)
Cb100n cafe racer
50cc scooter (now does 52 mph)
« Reply #31 on: January 03, 2019, 08:08:31 PM »
Paul. I will PM you my email so if you get stuck postings pics, email them to me and i will put them on the forum for you.
Offline Golfcarmad
« Reply #32 on: January 03, 2019, 08:42:00 PM »
Triumph TR25W
Yamaha Virago 1100
Suzuki GSX750ES
Yamaha Virago 535
Cb100n cafe racer
« Reply #33 on: January 03, 2019, 09:01:03 PM »
Photo from Paul of his tensioner on his CB400/4
« Reply #34 on: January 03, 2019, 09:03:21 PM »
I see what you mean, it's definitely not right and has been bodged by the looks of it. That bent bolt at the top isn't correct at all.
Offline Golfcarmad
« Reply #35 on: January 03, 2019, 09:06:18 PM »
I thought it was not correct.it looks like a snapped off bolt shaft in lower hole,is that were the tensioner adjuster bolt should be?
Triumph TR25W
Yamaha Virago 1100
Suzuki GSX750ES
Yamaha Virago 535
Cb100n cafe racer
« Reply #36 on: January 03, 2019, 09:08:06 PM »
Yes it is Paul.
« Reply #37 on: January 03, 2019, 09:15:06 PM »
This may help but you have probably seen it before
« Reply #38 on: January 03, 2019, 09:24:40 PM »
In fact Paul, if you have a very close look in that hole where the adjuster bolt goes, it may be OK. It is funny bolt with 2 different sizes on the same bolt, thinner at the inside end. You would need to get the correct bolt and see what happens when you fit it. Unfortunately, that still wont enlighten you as to what else has been broken or bodged inside.
« Last Edit: January 03, 2019, 09:27:10 PM by Nurse Julie »
Offline Golfcarmad
« Reply #39 on: January 03, 2019, 09:28:18 PM »
In the hole is a broken stud bolt.however the cam chain is nice and tight.the top hole is properly threaded and the bolt in the photo fits perfect-just no idea what it is supposed to do?
Triumph TR25W
Yamaha Virago 1100
Suzuki GSX750ES
Yamaha Virago 535
Cb100n cafe racer
« Reply #40 on: January 03, 2019, 09:57:35 PM »
I would guess it is being used to force the adjuster plunger in and over tension the camcahain
« Reply #41 on: January 03, 2019, 10:05:33 PM »
If you look at the picture above, the bolt you have fitted is No.11 (although the bolt you have fitted in there is totally the wrong bolt), it is just a bolt with a seal, it serves no other purpose. But as Bryan says, it looks like someone has fitted the incorrect bolt there to push the plunger down to give tention to the chain via the mechanism. This would suggest a very knackered camchain with loads if play that needed taking up.
« Last Edit: January 03, 2019, 10:07:31 PM by Nurse Julie »
Offline Golfcarmad
« Reply #42 on: January 05, 2019, 07:21:40 PM »
Stripped engine down to crank.plunger etc was fine but at min compression as locking bolt broken.had to drill out locking bolt,probably have to recap hole and hope I can fix.thanks for all help etc.Paul
Triumph TR25W
Yamaha Virago 1100
Suzuki GSX750ES
Yamaha Virago 535
Cb100n cafe racer
Offline mattsz
« Reply #43 on: January 06, 2019, 09:24:17 PM »
Back to wiring looms, brackets and tabs (oh my!)...
The twisted metal tab tacked to the cross member under the seat:
It's kind of hard to see in this photo, it's been smooshed down by the seat.  I assume that's the "wire clip" mentioned on page 17, step 50, in the dealer setup instructions?  It seems pretty big to hold just a few wires, and anyway the right side doesn't have one (the helmet holder is there).  It's very flimsy, and feels like it will break right off if I twisted it back into position.
Do I have it right?
EDIT: not sure why sometimes my thumbnails appear sideways - but a click on the photo to zoom in shows it up-side-up...
« Last Edit: January 06, 2019, 09:26:15 PM by mattsz »
« Reply #44 on: January 06, 2019, 09:41:09 PM »
Mine looks like yours Matt [ Guests cannot view attachments ]
