Author Topic: CB550F2/3  (Read 8675 times)
Offline heliwilly
CB550F2/3
« on: December 19, 2018, 10:36:50 PM »
Hi, Could someone give me the model designation of this frame Number, is it F2 orF3?
The DVLA gives the T reg number as manufactured 1979 and First Registered May 1979.
I thought the CB550's stopped being made in 1978??
I read the frame No as either CB550F 2411276 or CB550F 2111276
Your thoughts welcome. Bill W.
« Last Edit: December 19, 2018, 10:41:43 PM by heliwilly »
Re: CB550F2/3
« Reply #1 on: December 19, 2018, 10:40:17 PM »
It states it on the VIN plate, F2  ;)
CB550F 2111276 ??? So what is the number stamped on the head stock ?
« Last Edit: December 19, 2018, 10:50:42 PM by Trigger »
Offline heliwilly
Re: CB550F2/3
« Reply #2 on: December 19, 2018, 10:57:16 PM »
Thanks Graham, still a lot to learn.
Were the rear shocks fitted with open chromed springs or shrouded ones?
Bill W.
PS. What's the going rate for a full engine overhaul?
Re: CB550F2/3
« Reply #3 on: December 19, 2018, 11:03:03 PM »
From Graham via me 😀😀😀
Re: CB550F2/3
« Reply #4 on: December 19, 2018, 11:03:35 PM »
Bill W.
They have open shocks, the same as the 400 four.
Going rate  ??? Every engine is different and requires different new parts and different work  ;)
Offline heliwilly
Re: CB550F2/3
« Reply #5 on: December 20, 2018, 06:47:30 AM »
Thanks for the reply.
Bill W.
Offline deltarider
Re: CB550F2/3
« Reply #6 on: December 20, 2018, 08:09:03 AM »
There never was a CB550F3. A separate CB550F2 parts list can be found here: http://www.honda4fun.com/materiale-documentazione-tecnica/parts-list/parts-list-cb550 Compare the engine- and framenumbers listed in the first few pages of the parts list with yours, and you will know what model you have and what 'area code'.
« Last Edit: December 20, 2018, 09:12:09 AM by deltarider »
Offline LesterPiglet
  • 1977 CB550F2
Re: CB550F2/3
« Reply #7 on: December 22, 2018, 01:05:39 AM »
Never an F3 was made.You have an F2 tank, F2 frame, F1 side panels and aftermarket shocks. I don't recognise the black indicator brackets either.
'Then' and 'than' are completely different words and have completely different meanings. Same with 'of' and 'have'. Set and sit. There, their and they're. Set/sit. Bought/brought FFS. Bloody Americans.
Les Ross. Certified by a Professional
Re: CB550F2/3
« Reply #8 on: December 22, 2018, 07:15:02 AM »
They are same as 500 ones from US
Offline heliwilly
Re: CB550F2/3
« Reply #9 on: December 22, 2018, 01:47:09 PM »
LesterPiglet,
How can you tell they are after market shocks, or that the indicator brackets are wrong??
Were you looking at the photo Nurse Julie posted??
Bill W.
Re: CB550F2/3
« Reply #10 on: December 22, 2018, 03:41:12 PM »
LesterPiglet,
Bill W.
I think Lester is on about the photo i posted Bill. But, the tank is correct and so are the side panels for  a UK F2, the shocks are pattern ,TEC, as you cannot buy originals any more. The brackets are black and should be zinc plated. But hey ho, it's a work in progress restoration and has been off the road since about 1984 😀😀
Still looking for a set of NOS pipes if anyone has a set hidden away, i don't think Father Christmas is going to be of much help.
Offline hairygit
Re: CB550F2/3
« Reply #11 on: December 22, 2018, 03:59:51 PM »
LesterPiglet,
Bill W.
A long way from being N.O.S. but I've seen far worse get cleaned up and re chromed  e bay item  163427982193   looks to be all there.
Re: CB550F2/3
« Reply #12 on: December 22, 2018, 04:07:00 PM »
LesterPiglet,
Bill W.
Thanks Mr Hairy. I think Trig has seen them ones and decided against them.
