Brake master cylinders
Topic: Brake master cylinders (Read 6513 times)
jappersx
May 17, 2008, 09:44:58 AM »
ive put a brake master cylinder on my cb500/4 from my cb650z and its fine apart from the brake light not coming on .light works ok with back brake peddle ,any clues as to what is going on
Re: Brake master cylinders
May 17, 2008, 11:12:58 AM »
Nothing to do with master unless you bypassed the 3 way block bolted to the bottom yoke,
Front brake light on 500 is operated by a Hydraulic switch in the 3 way, sometimes the wires get disconnected when working on the bars
SteveD CB500K0
Administrator
Ride on the Steel Breeze...
May 17, 2008, 10:12:27 PM »
I assume that you added the poll by mistake so I deleted it. If not the case let me know (sorry)
