Author Topic: Shell Helix oil  (Read 4570 times)
Offline adespin
Shell Helix oil
« on: January 28, 2019, 12:50:23 PM »
Does anybody use Shell Helix HX7 10/40w semi synthetic oil in their 750, any reason not to use it?
1971 cb750 K1
Re: Shell Helix oil
« Reply #1 on: January 28, 2019, 01:01:55 PM »
Too bloody expensive for 1500 mile changes and i personally dont like anything with synthetic in the name and wet clutches.
Tesco own brand none synthetic is the right spec.
Re: Shell Helix oil
« Reply #2 on: January 29, 2019, 09:31:43 AM »
Thought you used Fuchs Titan Bryan?
Re: Shell Helix oil
« Reply #3 on: January 29, 2019, 10:18:56 AM »
Nope i still have some Transfleet left i bought in bulk years back but would use the Titan if there was a local supplier, i was trying to give an easy to get answer.
Offline adespin
Re: Shell Helix oil
« Reply #4 on: January 29, 2019, 11:59:39 AM »
The reason for my question is i'm looking for a reasonably priced quality oil for the Honda and spotted this on ebay, https://www.ebay.co.uk/itm/Shell-Helix-HX7-SAE-10W40-Part-Semi-Synthetic-Car-Engine-Oil-A3-B4-5L-5-Litre/232880236089?hash=item3638be6639:g:4KQAAOSwFqpbbA9E:rk:7:pf:0
and it's 5 Litres not 4.
« Last Edit: January 29, 2019, 12:01:21 PM by adespin »
1971 cb750 K1
Re: Shell Helix oil
« Reply #5 on: January 29, 2019, 12:35:07 PM »
Wow that's not a bad price, looks good give it a go you can always take it out again. But as Bryan says it's semi-synthetic so watch out for your clutch slipping. I have been using this recently after a few recommends.   https://www.ebay.co.uk/itm/Fuchs-TITAN-FORMULA-15W-40-High-Performance-Engine-Oil-5-Litre-5L/132218967063?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
It appears to be fine with the added bonus that it slightly quitens the clutch rattle on the 750, although getting rid of the clutch rattle altogether will require divine intervention. ;D
« Last Edit: January 29, 2019, 02:41:13 PM by royhall »
Re: Shell Helix oil
« Reply #6 on: January 29, 2019, 01:46:11 PM »
API SN/CF; ACEA A3/B3, A3/B4, JASO SG+
Approvals: Mercedes Benz approval 229.3; VW 502 00/505 00; Renault RN0700, RN0710. Meets the requirements of Fiat 955535-G2
Synthetic technology motor oil
Shell?s unique active cleansing technology actively locks away harmful performance-robbing deposits
Active clean-up helps to remove sludge left behind by inferior oils2
Excellent wear protection3 helps to extend engine life by protecting against wear, even in daily traffic conditions
Excellent resistance to degradation helps to maintain protection throughout the oil-drain interval
Multi-fuel capability - can be used for petrol, diesel and gas engines, and is also suitable for biodiesel and petrol/ethanol blends
With its unique cleansing technology, Shell Helix HX7 goes on cleansing and protecting to help keep your engine clean and running efficiently. Formulated with synthetic technology, Shell Helix HX7 makes use of both synthetic and mineral base stocks to achieve higher performance levels than can be formulated from mineral oils alone. It provides excellent resistance to degradation to help maintain protection throughout the oil-drain interval. It also helps to reduce evaporation to help provide low oil consumption.1 1 Based on NOACK volatility test and equipment manufacturers? requirements 2 Based on a severe sludge clean-up test 3 Based on Sequence IVA engine test carried out at an independent laboratory
Copied from their info sheet.  As normal with most of these descriptions it's going to do absolutely everything for you along with cleaning up everyone else's mess that's been made inside your engine!!!  ;D
I wouldn't worry about the "semi/part synthetic " labelling as it's mostly marketing puff. It largely equates to sharing a shelf with something identifying as synthetic in all practical reality. There's a bigger story as to why oils are labelled as such without being what we'd normally understand as to what synthetic actually means.
Can't see it as a problem to use it,  seems a decent quality oil and seriously doubt you'd encounter any concerns.
Shell Helix oil
« Reply #7 on: January 29, 2019, 04:30:42 PM »
One word of caution (purely based on experience rather than any empirical evidence) - in my experience semi-synthetic oils in our engines have a habit of finding leak paths. Don’t ask me why / how, but I’ve had oil tight engines suddenly start sprouting leaks after an oil change to semi-synthetic. I generally stick with 10w/40 mineral oils.
Re: Shell Helix oil
« Reply #8 on: January 29, 2019, 04:47:53 PM »
As an owner of an old air cooled Porsche, I also have to hang about on forums dedicated to them, the general consensus is that modern oils are too slippery for the oil seals designed for old fashioned dinosaur oil, and will make a bid for freedom where they can.
Offline Moorey
Re: Shell Helix oil
« Reply #9 on: January 29, 2019, 09:07:15 PM »
This isn't dear. Less than £3 Ltr.
eBay item number:
302901738600
