550K1 fork oil
Topic: 550K1 fork oil (Read 3250 times)
Davelu88
550K1 fork oil
February 03, 2019, 05:47:50 PM »
Hi all, anyone know how much fork oil should be in a 550K1 and what oil to use , searching brings up varying opinions.
Johnwebley
Re: 550K1 fork oil
February 03, 2019, 06:06:01 PM »
Assuming it's the same as the 500.
Try 160cc atf oil
Davelu88
Re: 550K1 fork oil
February 03, 2019, 06:08:34 PM »
Cheers John
Nurse Julie
Re: 550K1 fork oil
February 03, 2019, 06:09:34 PM »
Or ATF
Trigger
Engines built on reputation, not advertising.
Re: 550K1 fork oil
February 03, 2019, 06:11:12 PM »
Sorry to correct you John, it is 164.997 cc
and that is on a full strip and clean. If just a drain from the side bolt then totally different
Davelu88
Re: 550K1 fork oil
February 03, 2019, 06:14:54 PM »
Just a drain & replace Graham , so what would that be. cheers
Trigger
Re: 550K1 fork oil
February 03, 2019, 06:39:32 PM »
It is very hard to get it correct with a drain. You can be out by 10cc on each fork but, the book says 135 to 145cc
deltarider
My kingdom for a turkey!
Re: 550K1 fork oil
February 03, 2019, 06:58:00 PM »
My CB500K2 (ED) has the same legs. I personally have best results with 140cc 7,5 weight.
Davelu88
Re: 550K1 fork oil
February 03, 2019, 07:48:21 PM »
550K1 fork oil
