Author Topic: Steering lock  (Read 6103 times)
Offline 3scs
Steering lock
« on: February 09, 2019, 11:31:50 AM »
Would anyone know why my steering stem doesn’t have a hole in it for the steering lock it’s a cb 550k3 which has many parts from an f1 fitted to it but according to cmsn the steering stem is the same for both models
Re: Steering lock
« Reply #1 on: February 09, 2019, 11:43:56 AM »
Because its not a K3 stem.
The K3 has a lock in the side of the headstock and the pin goes into a slot milled into the srem tube.
Earlier ones fit into the lower yoke and the pin goes upward to lock on the steering stop on frame.
Offline 3scs
Re: Steering lock
« Reply #2 on: February 09, 2019, 12:03:01 PM »
The plot thickens looks like the only part of the bike which is definitely k3 is the frame
Re: Steering lock
« Reply #3 on: February 09, 2019, 02:43:06 PM »
Worry not, the only parts of my original CB550/4 K3 left are the frame, top and bottom yokes and 2 wheel hubs.....she's not called Millie the Mongrel for nothing 😀😀😀😀
Offline 3scs
Re: Steering lock
« Reply #4 on: February 09, 2019, 10:05:13 PM »
Thanks for the kind words Julie Millie the mongrel is a well designed masterpiece but Billie the bitsa is a cobbled together lump in need of a bit of tlc I will get there though 😉
Re: Steering lock
« Reply #5 on: February 09, 2019, 10:06:35 PM »
If you have the lock hole in the frame you could cut the slot in the stem to take the pin.
Offline 3scs
Re: Steering lock
« Reply #6 on: February 10, 2019, 05:55:49 PM »
That’s the plan
